Seat Belt will not pull out
Old Mar 12, 2007 | 11:08 AM
jcltc's Avatar
jcltc
8th Gear
Default Seat Belt will not pull out
I have a 1984. The last time I used the seat belt it failed to retract fully. Now, it will not pull out far enough to fasten again. What is the fix?
Old Mar 12, 2007 | 01:19 PM
thumper823's Avatar
thumper823
im not sure about corvettes, but some vehicle seat belts are touchy and need to be pulled slowly, if that does'nt work, have they ever been swapped out? if they sit a little crooked they will not come out. other than that the tensioner may be worn out and need to be replaced. anyone else have an opinion?
Old Mar 12, 2007 | 01:29 PM
C4Robert's Avatar
C4Robert
on mine there is a place where they sewed a spot in it so that it wont retract to far so sometimes that place gets stuck and you have to pull kind of hard to get it through the top bracket. other than that sometimes its tempermental to get it to go all the way back in and out. just move it around.
Old Mar 12, 2007 | 05:04 PM
Yellow2015's Avatar
Yellow2015
There was a recall on seatbelts. I'm not sure if it covered 84 but on my 88, I brought it to the chevy dealer, they looked up the VIN and saw that the recall hadn't been performed on the car so they ordered me TWO sets of seat belts and installed them under the recall campaign. You might want to check with a dealer. As far as I know there is no statute of limitation on a "safety related recall. Mine were done 4 years ago which made it 15 years old.
http://forums.corvetteforum.com/show...t+belt+recalls
Old Mar 12, 2007 | 06:24 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
I just give it a good fast yank, and it pops right out..
Old Mar 12, 2007 | 07:06 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
yes there is a recall. Dealer should fix free.
http://www.internetautoguide.com/aut...ase/index.html
Old Mar 12, 2007 | 10:20 PM
Yellow2015's Avatar
Yellow2015
Great info. To cover all the bases though, ask if the campaign covers BOTH belts. I had two different campaign numbers. One for the drivers side and one for the passenger.
Old Mar 13, 2007 | 04:03 PM
Cruisinfanatic
from what I understand, all belt assemblies aren't automatically replaced. Only non working ones.
Old Mar 13, 2007 | 04:59 PM
Yellow2015's Avatar
Yellow2015
That is true. However my dealer said that given the age of the car, it would be just as easy to change both sides while they had the car.
To Seat Belt will not pull out
