88 needs new injectors
Old Mar 12, 2007 | 12:42 PM
bruced267's Avatar
bruced267
Default 88 needs new injectors
We have an 88 with about 90k on it and it needs new injectors. Do you guys have any recomendations? I was thinking about a set of Bosch injectors but I think they are 29lb? what is the stock lb rateing? If I went with the 29lb injectors would it pose a problem? or would I have to install a adj fuel pressure regulator? Thanks in advance
Old Mar 12, 2007 | 12:54 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
I think your stock are 22lb.... why go to 29lbs? go to Five-O-Motorsports for injectors... good guy and price is nice.
Old Mar 12, 2007 | 01:04 PM
Aardwolf's Avatar
Aardwolf
How do you know they are bad? Rich at Cruzin performence will clean the stockers.
Old Mar 12, 2007 | 02:06 PM
bruced267's Avatar
bruced267
Leak down, hard starting already performed the test. I was also thinking of sending them out for cleaning. Would that fix them?
Old Mar 12, 2007 | 02:08 PM
vader86's Avatar
vader86
Stock is 22lb/hr. If I recall correctly 88 doesnt have the Multec injectors, which means yours can be serviced. (I thought multec's started in 89, cant recall for sure) If it does have Multecs, then Rich wont touch them.
You can either do that or replace them with Ford SVO #24s and buy an AFPR to go with it.
Old Mar 12, 2007 | 09:44 PM
Kool88vette's Avatar
Kool88vette
They are not Multechs. Send them to Rich at cruizinperformance. Don't use five0motorsports. Do a search of fiveomotersports on this forum.
Old Mar 12, 2007 | 11:50 PM
Sam Lam's Avatar
Sam Lam
with the above. I believe stock injectors for your car are 22.5 lb/hr injectors. The injectors in your car can probably be useable for about $100 for cleaning and flow testing by Rich Jensen at Cruzinperformance. Here is his email address: rich@cruzinperformance.com. He is a good guy and will be straight with you.
Here is a tech article for removing the injectors without pulling the runners and this may be of value to you if you do the work yourself: http://webpages.charter.net/buddiel/...al)%201-04.doc
Putting in larger flow injectors will just add to the problems with your car.....unless you compensate to the increased fuel flow by a new chip and fuel pressure regulator. More fuel does not make it run better!!!
Old Mar 13, 2007 | 01:21 AM
vinnies87's Avatar
vinnies87
Nothing wrong with 5-O, i've done business with them and 2 sets of injectors and have only great things to say...
To 88 needs new injectors
