I've tried leaving them overnight in carb cleaner and nothing.
Wire wheel also doesn't work.
Only thing that would work that I can think of is putting them into drill
and sanding them, but than would probably damage valves.
And the best way. Replace them with larger (2.00/1.56) necked, cut-back swirl-polished SS performance valves and have the seats ground (with 3-5 angle valve job) to fit the new valves.
You could take a wire wheel to them, if SS, they should survive.
Hi Sliding !
do you have the "Chillit Bang" cleaner in Croatia?
Use it.... fill a glass with the needed amount to cover the valve. let it sit overnight. then repeat the next night.
valves will become as new!
-Beppe-
