intake manifold gasket replacement Question
1: How much does a GOOD gasket actually cost and what is a good site to order from?
1 and 1/2: is the the gasket a gasket set or just one gasket?
2:Is there any site that offers some assistance maybe with some pics and steps just for some extra confidence in doing this?
3:What are the torque specs or where can I find them to torque properly?
4: Will there be any SURPRISE items I should be aware of? (I don't need to be there again
Please any help would be greatly appreciated.
Pick up a top end Fel Pro gasket set at AutoZone (~$35 for my L98) and go for it.
On my L98 the set provides all gaskets needed to remove/replace the intake including the base. It even comes with a small tube of black RTV.
Lotta guys here prefer the Right Stuff instead of RTV though the latter has worked well for me.
I can't help with the top end details of the LT1 but can with properly sealing between the base & engine lands as well as heads.
http://forums.corvetteforum.com/show...et+replacement
Good Luck
Do not for any reason crank the car until at least 24 hours after you bolt the intake back on. That is, unless you can't wait to do the job all over again. I learned this years ago the hard way, and had to pull a Super Ram twice.
One thing that gets me...you said 750 for labor...wow,whats the labor rate and how many hours for the job?Im just curious.
It does not take that long for a experienced tech to do the job and I cant imagine why 7 hours is required,unless they are using book labor quotes.
1) By the GM or Felpro gasket kit. ~$35 from Chris May at Superior Chevrolet (forum sponsor, be sure to tell them) for the GM kit or about the same for the Fel Pro kit from Summit, Jegs, etc. FWIW I like the GM stuff
The "kit" will come with the two gaskets (one/side) that fit between the intake and the cylinder heads. The end seals are RTV. The Right Stuff is good, as is the FelPro brand of RTV.2) Not that I'm aware of, but it's not a big deal to do. The LT1 intake is dry, so you don't need to drain the coolant (there is coolant that runs thru the throttle body, but those lines are easy to cap as you remove them). Book time is ~4 hours.
3) On my '96 it's 35 Lb/ft as I recall. Your '92 may be different. This is where a real service manual pays for itself. You also have to torque the bolts in sequence.
4) No need to remove the fuel injectors from the fuel rail. Just unbolt the rail from the intake and then lay the whole assembly on the windshield on a towel. Be sure to clean/vacuum around the edges of the intake before pulling it off to keep debris from falling into the ports or lifter valley. Use ****new**** razor blades (I typically use 1/side) to remove the old RTV and gasket material...it makes it soooooo much easier.
If it's never been apart, you'll need a new throttle body to intake gasket, as well as a gasket for the EGR valve and the AIR tube. Should also probably replace the o-rings that go around the injector tips (this is why it's easier to just order all the stuff from Superior versus trying to source it all over the place) Good time to replace the pcv valve. Be careful with the plastic vacuum lines and check valves...they get old and brittle.
Intake manifold gasket set, EGR valve gasket, AIR tube gasket, Valve cover seals (gaskets), Throttle body gasket, Injector "O" rings.
The success of this job will depend on the quality of the bead of silicone you apply to each "china" rail before the manifold is set in place. It is extremely important that the block and manifold end surfaces and the corner crevices are very clean and dry before applying silicone. Acetone, lacquer thinner or brake cleaner works well for this. Try to run a continuous even bead of silicone about .200 diameter with a small additional amount in each corner. I usually put a dab in the corners first before running the bead. Let it cure for 24 hours before starting the engine.
Some one asked about how the dealer priced me for $125 and $750. Well Im in Germany and Everything here is expensive. It would be even mor if i wasnt in the military. They save me from the 19% tax. YA 19%.They quoted me for 100 Euro for the gasket and (ABOUT) 600 Euro for Labor. They charge 80 Euro an Hour. So I guess they figured 7 hours and some change. I have already payed up the wazzoo for having a new clutch and Flywheel put it, I would be embarrassed to tell you what I payed for that. I have learned now to buy my parts from back in the states and ship them here. Its kind of like how Porsche would pay up the wazzoo for stuff done to his car in the states. Trust me though its all worth the while when you can go out on the autobahn as fast as you want for as long as you want. I took a ride to a town about 40 mins away I was able to keep it at about 120mph most of the way and occasionally hit 150mph+ I love this place. Keep up the good work. Thanks for your help
