Calling Pete K for 4l60E Tech Assisitance
Old May 16, 2007 | 10:49 PM
  #41
Pete K's Avatar
Pete K
Originally Posted by 95BLKVette
Guess you aren't around tonight Pete
I am now
I suspect that your troubles are over. Enjoy the ride
Old May 16, 2007 | 11:09 PM
  #42
95BLKVette's Avatar
95BLKVette
So Pete, she shifts fine and doesn't overheat...drove home in bumper to bumper traffic cause of the storms tonight didn't go over 203F.
One question...think its break-in related.
Only have 100 miles on it now and noticed when converter is in lockup and I push it to just before it downshifts the TCC clutch (new refurbished converter) shudders a little just before the downshift. If I nail the throttle, this doesn't happen, it just dowshifts and kicks ***
I did notice that the above situation has gotten a little smoother over time. Is this a normal break in procedure for the TCC clutch or is the TCC slipping a little under high torque load ?
Old May 16, 2007 | 11:14 PM
  #43
Pete K's Avatar
Pete K
The converters I sell do the same thing for a few hundred miles or so, then they usually tame down. The carbon cluch lining is the cause.
I presume protorque converters use the same(or similar) lining.
I would not worry about it.
Old May 17, 2007 | 12:37 PM
  #44
95BLKVette's Avatar
95BLKVette
Thanks Pete.
BTW, it's confirmed the excessive pump rotor & vane clearance was my problem, as I got up to 213F today in drop dead stop and go traffic and everything was fine. Forward clutch pack didn't realease as it had in the past.
Think you're right, as it seems like it only shudders just a little above 65mph when I push it hard just prior to the TCC clutch disengaging. Doesn't happen below that speed as I belive it downshifts to third at that lower speed. Also, doesn't happen when leaning on it at lower TCC engaement speeds.
