c6 wheels on c4
Old Mar 13, 2007 | 08:49 PM
excessive81's Avatar
excessive81
Default c6 wheels on c4
i was told these would bolt right up but they wont. the frontds will but need a spacer tolook correct. the rears are hitting hard parts so will need a spacer to work to. will see if 1" is enough tommorow. rapping my zr2 to see...lol
Old Mar 13, 2007 | 09:09 PM
97AGGIE's Avatar
97AGGIE
Mine fit. What year are you trying to install them on?
Old Mar 13, 2007 | 09:35 PM
JA94vette's Avatar
JA94vette
VERRRRRRRRRRRRRRY NICE VETTE!!! I really like it. I'm not a fan of wings but it looks great on yours!!
Please post some more pic of your vette!! Also, what size and kind of tires are thoes? What size wheels? I have been thinking about C6 Z06 wheels for a while but I really want to get them in silver.
How did you get it that low? Coil-overs?
Old Mar 13, 2007 | 09:37 PM
Draven's Avatar
Draven
St. Jude Donor '14
They will bolt up to an 88-up. Pre-88 will require spacers or a different offset.
Old Mar 13, 2007 | 09:40 PM
97AGGIE's Avatar
97AGGIE
Thanks JA! I appreciate it. They are the 18x 9.5 all around. 275's up front and the 315 30's in the rear. BFG G-force drag radials in the rear and the normal G-Force up front....and yes...I have QA1 12 way adjustable shocks w/coil overs on the front and Doug Rippie Bilstein conversions on the rear.
Old Mar 13, 2007 | 10:06 PM
Brian9's Avatar
Brian9
315's on 9.5's? post some more pics of the tires if you can! oh and the whole vette looks nice... i love yellow and i of course i like chrome c6 z06 wheels especialy since i have them on mine
Old Mar 13, 2007 | 10:15 PM
97AGGIE's Avatar
97AGGIE
Thanks! I dont have any close ups of the rears...but they do fit just fine. A lot of peole will say that they dont fit, but I have been using them for over 10 years this way. (Of course at the time I had 17x9.5's)
Old Mar 13, 2007 | 11:56 PM
Brian9's Avatar
Brian9
Cool thats good to know Youve got a very nice vette you need to post more on the forum and share more pics when you get them!
Old Mar 16, 2007 | 10:37 AM
excessive81
mine is a 90. my c6 wheels a stock gm wheels from my c6. are yours repops. i ordered 1.5 in spacers for the rear and am looking for 3/4's for the front. likei said the rears would even bolt on they where hiting th the frome up by the door. the fronts went on but are to inset for my taste....n your cars is HOt!!!!! just reread you post you have 18's on the back...i will have the staggered 18/19's. i know you can get order the right setup i was just reusing wheels i have
Old Mar 16, 2007 | 03:28 PM
97AGGIE's Avatar
97AGGIE
Thanks..I appreciate it. My wheels are factory originals. I just purchased 4 18x9.5's instead of going w/the 19's in the rear mainly b/c there wasnt really a good drag radial in a 19. Not sure why you are having problems w/them fitting. There really is no reason you should be having to use that thick of a spacer. I would be real careful doing that w/stock wheel studs.
Old Mar 16, 2007 | 04:05 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Dayum!! Look at THAT profile!!!
The C5's will NEVER look THAT good.
C6? Forgettaboutit. C6 style is worse than C5.
BTW, What brand luggage rack is that? I'd like one of those on my Vette.
Old Mar 16, 2007 | 06:56 PM
97AGGIE's Avatar
97AGGIE
Thanks VetNut! I appreciate it! As far as the "rack"...It has been a while...I bought it back in 1994! I think it was a local place here in Houston...I believe that they were called MidWest Designs. I dont think they are in business anymore.
Old Mar 16, 2007 | 07:20 PM
corvettedan22's Avatar
corvettedan22
Yes they do look great !!!!!!!!
I went with non zo6.
I have an 85, and am waiting for my spacers. 34mm in the front 38mm in the rear,
for the z51 off set
Old Mar 16, 2007 | 08:24 PM
excessive81
you have four fronts. the spacing on the rears or diffrent. it is a wheel adapter not a spacer. the adapter bolts to hub then wheel bolts to adapter. i have 2.5 an 1 inch on my blazer and used the 2.5s on my c6 before i got my new wheels so they would work wih my z fenders. it had 400 hp to the wheels at the time and had no issues
Old Mar 17, 2007 | 09:02 AM
97AGGIE's Avatar
97AGGIE
Gotcha. That makes sense. I was thinking it was one hell of a thick spacer! LOL! Post some pics when done!
Old Mar 17, 2007 | 10:10 AM
excessive81
i will be sure to. car looks 10 years newer with just the fronts!!!! once agian you ride is SWEET!!!!!! the z wheels and the stance is killer....later
Old Mar 19, 2007 | 04:40 AM
buda052's Avatar
buda052
To confirm, do the wheels have the 53mm offset? As for the front tires, 275/35's? 35's would make things close to the 315/30's in the back.
Looking to go this route, but trying to figure out the specifics for the rear, 18x9.5, 18x11, 19x10, 19x11 or the monster 19x12. And then the offset question.
Old Mar 19, 2007 | 07:06 AM
ToniH's Avatar
ToniH
Of course they do fit the wheel but tyre manuf. recommend minimum 10.5" wide wheel for 315 to make it work properly. Look at your picture closely and compare the sidewall shape of your front and rear tyre. The rear bulges badly and is clearly incorrect. This means it does not provide proper sidewall support. Doesn't matter much if you are just going straight but you can feel the difference in corners.
And I too used to run BFG 315's on 9.5" wheels until I got bored with the soft feeling and bought correct tyres to my car.
Old Mar 28, 2007 | 04:41 PM
LD85's Avatar
LD85
Is this a factory yellow color?
To c6 wheels on c4
