Need Help with Temp Sensor
Old Mar 13, 2007 | 11:27 PM
My Jersey Girl's Avatar
My Jersey Girl
Default Need Help with Temp Sensor
I had to replace the Temp Sensor on my 93 LT-1 coupe. This one is on the water pump. I ordered the part (Part Number 25037332) and installed it but when I went to connect it, the pins are different. The old one has two pins and the new one is a pin and blade. So my question is can I change the wire plug or do I have to replace the sensor? If I have to change the Sensor does someone know the part number to it.
