? for Pete K.
If I understand you correctly, it is a no shift.
Check the following carefully:
1)Governor assembly.
This includes a stripped gear, hung up yalve or worn weight pins.On hi mile cars, the axle pins actually wear quite a bit.
2)The screen that feeds the governor.
Might be blocked or collapsed
3) severely worn seperator plate
(from check *****)
4) Worn scarf cut seals on second apply piston(servo)
(not likely)
5)Servo check ball capsule not sealing. Change this regardless (during the rebuild)
(from check *****)
(not likely)
Yes, revved to the moon and felt like it was in neutral. When it revved back down it would slam down into gear and then drive. Like I said it did it probably 3 times in a couple of months. Gotta fix this, it felt like the whole rear end fell to the cement. Gonna learn how to rebuild in a couple of weeks!!!!!
If the trans is low milage, it is typically tv valve problems that contribute to the failure. Often, misadjusted cable.
Governor problems can also contribute to a hurt 3-4.
You will see the frictions will likely be black(burnt) upon disassembly.
Take lots of pics
