ABS Question
Old Mar 15, 2007 | 09:02 PM
Black-Cloud's Avatar
Black-Cloud
Cruising
Default ABS Question
What would make the ABS light come on as soon as I hit the brakes? This is on my 90.
Black Could
Old Mar 15, 2007 | 09:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well if you aren't on a slippery surface, check your brake fluid level.
Old Mar 15, 2007 | 09:40 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
"service ABS" or "ABS active"?
Old Mar 18, 2007 | 06:50 PM
Black-Cloud
Cruising
Default ABS Light
I'm not sure as my car is not out of the cold as of yet. Still getting snow in CT, but it is the light in the info panel. I do belive it is the Service ABS.
Thanks for any help you msy have.
Black-Cloud
Old Mar 18, 2007 | 07:30 PM
IRAraid's Avatar
IRAraid
Default ABS light
I had a '96 Blazer that did that (ABS light came on when the brakes were applied but obviously no tire slip) and it was a cut sensor cable. The lead was rubbing the wheel and eventually wore through, grounding against the wheel. Inspect the ABS sensor leads very carefully.
Hope this helps.
Old Mar 18, 2007 | 11:18 PM
Trog's Avatar
Trog
A factory sevice manual would tell you how to check the code(s) behind that service light. I have a '90 as well & have had to check front sensors a few times over the years (based on the codes I've pulled). They have always checked out but the connectors under the dash seem to like attention on occasion or something.
Old Mar 21, 2007 | 08:50 PM
Black-Cloud
Cruising
Thanks I will pull the wheels off and look around .
To ABS Question
