slow throttle response when revving
the car seems to rev a tiny bit slow when giving steady gas. Also if just flip the throttle open from under the hood from idle it takes about 1/4 second for the the engine to rev up...i here a sucking noise which i assume is the TB sucking in air. I just finished big tune-up (plugs, wires, dist. cap/rotor fuel pump...etc. but i haven't taken off the TB to clean it or any of the sensors. Just wondering if i can quicken up that rev or it's normal for that little delay when tapping the gas from idle.
If I were you, cleaning the TB always helps... I'd go for it. Pull it off, clean up the TB and IAC really well. Be care and make sure you use TB cleaner specficially. Also, don't go too crazy when cleaning your IAC. Once you're all done with that, reattach it and might as well go through the steps to verify your idle is set correctly. You'll be setting the TPS to specific volts correctly then.
FSM stands for factory service manual. It's a must have if you're going to be working on your vette.
If you check out the tech tips, it has a good write up on cleaning the TB and resetting your idle along with it.
Also, think about running some Sea Foam through your intake and fuel system.
There are many things that could be causing your issue... just keep it simple... fuel, air, spark. Troubleshoot those and you'll be on the right path.
Also, I agree with RRT... I too have a slight hesitation, but nothing that makes me go too
This stopped all of that. I don't know if this is the same type situation though.
Macfos
