Driver Window Droops
Old Oct 11, 2001 | 04:52 PM
Easy95&64's Avatar
Easy95&64
Default Driver Window Droops
My driver side window on my 95 coupe is droopinga bit. This causes it to hit the body at the top back and it does not line up with the weatherstrip and leaks. Has anyone else had this problem? :confused:
Old Oct 11, 2001 | 05:36 PM
champ's Avatar
champ
Default Re: Driver Window Droops (Easy95&64)
Sounds like the "window guide' to me. This is a [plastic piece that fits on the window inside the door. Piece is GM part. Pick up the part and go to any auto glass store ans have them install it. Well worth the money if you do not have the tools.
Old Oct 12, 2001 | 12:33 AM
Rick Williams's Avatar
Rick Williams
There are adjustments for the window if you remove the door panel. I just had my drivers door window adjusted when I had a new top installed. A glass shop could do that for you..
Old Oct 12, 2001 | 11:03 PM
Dualnic's Avatar
Dualnic
This is what champ is talking about....i also had the same problem my passenger window was rolling to far up front and not stopping...causing the rear to **** down resulting in the top rear part of the window to hit the body when closing the door. The pic number(6) guide/stop is the left window as u can c from my pencil marks 37 is drivers and 38 is passengers..if i can remember correctly, btw it was a pita to remove the bolt/nut so be very carefull not to break the glass....there was a special tool i order from snap-on to place on the nut which made the job just a bit easier.
[Modified by Dualnic, 9:10 PM 10/12/2001]
To Driver Window Droops
