skinnies up front
Old Mar 16, 2007 | 04:19 PM
hgh pwr's Avatar
hgh pwr
Default skinnies up front
I'm interested in running skinnies up front and I have the gs brakes on my 94 , is there any interference problems.
which brand of wheel is best (weld)? thanks
Old Mar 16, 2007 | 04:37 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
15" rims won't clear the caliper. Not recommended, but some folks went with a spacer to clear the caliper, some have converted to the smaller brakes.
Here's my '93 with the standard brakes, you can see how close it is.
Old Mar 16, 2007 | 07:07 PM
97AGGIE's Avatar
97AGGIE
I run 15x3.5 weld's and have the GS calipers w/13 crossdrilled rotors. Just install a set of hardened aftermarket wheel studs in the front (good idea when running a spacer), then run a 3/8 spacer. I have no probs!
Old Mar 18, 2007 | 04:58 PM
Snakeskinner's Avatar
Snakeskinner
Run this set up also
I put in extra length s-10 studs that I got @ Advanced
AP ,to make sure enough thread engagement,also
suggest open end lugnuts,to make sure you are not bottomed out against the closed head nuts & you can visually check depth of engagement.I recently went with some billet 1/2" spacers from MIDWest AP
Old Mar 18, 2007 | 06:43 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
I run same welds.
I use 5/16 specer.
Went with 1/2 dia... long studs.
Same in rear.
Matt383
To skinnies up front
