adj. strut rods??
Old Oct 11, 2001 | 06:50 PM
88sk's Avatar
88sk
Default adj. strut rods??
anyone here have adj. strut rods , seen them in mad catalog for $100.w/ poly bushings, Im puttin new tires on & gettin alignment , want to know if they are worth buying ???
Old Oct 11, 2001 | 08:49 PM
Bills17n72's Avatar
Bills17n72
Default Re: adj. strut rods?? (88sk)
Hello there
Yes I put a set on my 79 ,it is a little work but im glad I did.once you get them adjusted then they cant move .
Bill B
Old Oct 11, 2001 | 10:09 PM
No Go's Avatar
No Go
I looked at putting them on my 96, but decided to spend my money elsewhere since the car already has adjustable strut rods. They use an eccentric rather than the jam nut type adjustment. I believe the jam nut is less likely to "drift", but if the factory eccentrics are tight then they work.
Now if you change your camber often then I could see this being pretty useful cause getting that eccentric just right is a pain!
To adj. strut rods??
