TCI Line Lock Question
Old Mar 17, 2007 | 04:27 PM
mn_vette's Avatar
mn_vette
Default TCI Line Lock Question
Hey guys,
Has anyone installed a TCI line lock? I've got the thing installed by putting the front brake line directly into the solenoid and a line from the solenoid into the master cylinder. The problem is that the lines that attach to the solenoid seem to be loose. The nuts are tightened down all the way but the lines still seem to be able to turn. They don't move in and out, but they will rotate.
Is this going to leak like a seive when I get it back together? Do I need some kind of adapter between the lines and the solenoid? Or am I just fussing about nothing?
Old Mar 17, 2007 | 04:54 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
sounds like you need an adaptor
Old Mar 17, 2007 | 06:54 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
That's the difference between metric and standard. I think when I did mine, I bought a Hurst, there was an installation kit that came with it with the proper fittings and plugs for the solenoid and the two tubes were joined before they went into the solenoid. Similar to what's pictured below.
Old Mar 18, 2007 | 05:54 PM
mn_vette's Avatar
mn_vette
Thanks guys,
I picked up some adapters today. They aren't the compression type like shown above, they look more like a female brake line fitting on one side and a male thread on the other. Hopefully it will work out just fine.
To TCI Line Lock Question
