Mass Air Flow screen removal
Old Mar 18, 2007 | 01:10 PM
TPI84GMC's Avatar
TPI84GMC
Default Mass Air Flow screen removal
Whats the best way to remove the screens with out damaging the Mass Air Flow sensor?
Old Mar 18, 2007 | 01:30 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Put it in a padded vise and use a very thin bladed knife to separate each end from the barrel. The ends holding the screens are glued on.
Old Mar 18, 2007 | 01:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Use needle nose pliers, punch them in a little and grab and pull. once you tear the screen enough you can pull it all out by hand.
Old Mar 18, 2007 | 02:49 PM
LD85's Avatar
LD85
I clamped mine in a vise on the milling machine and just plunged them out
Old Mar 18, 2007 | 05:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That was my method.
I ran a knife blade repeatedly around the groove and then gently pried with a screw driver blade till the end caps "poped".
Once the end caps are off the screens just come right out.
Further I suggest you carefully place duct tape over each end of the internal sensor tube and cut off the heat sink fins. Blow out and wipe out all Al dust before removing the duct tape.
Old Mar 18, 2007 | 11:42 PM
ozvette87's Avatar
ozvette87
Originally Posted by 65Z01
That was my method.
that is way too scary a job
Old Mar 19, 2007 | 12:02 AM
65Z01's Avatar
65Z01
Trust me, nothin' to it.
I cout out the heat sink fins with a round hack saw blade and dressed them with a file.
So long as the duct tape is over both ends of the center sensor tube the delicate wires are not in jeopardy.
And remember that the '86-'89 Vette MAF is compatable with the '86-'89 F-body TPI cars, either 305 or 350cid.
In fact the '88 Vette is still running fine on the MAF from my old '86 IROC-Z.
Old Mar 19, 2007 | 12:26 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Needle nose pliars, it pops right out.
Old Mar 19, 2007 | 05:29 PM
All2kool's Avatar
All2kool
Old Mar 20, 2007 | 05:53 AM
Desert1957's Avatar
Desert1957
Default question for all about this MOD
Originally Posted by All2kool
What are the Performance advantages from this Modification? anyone chime in.
Desert
Old Mar 20, 2007 | 07:08 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Desert
Next to nothing
Old Mar 20, 2007 | 09:48 AM
tlong's Avatar
tlong
The screen evens out the air flow for the little sensor to read. Removing the screen lowers restriction in theory. I doubt it adds tire shredding power on the scale of a throttle body air foil.
Old Mar 21, 2007 | 01:57 AM
TPI84GMC's Avatar
TPI84GMC
I read somewhere online (who knows where now...) that some one bench flowed with and without the screens and it only does 570 CFM with and upwards of 650 without. It may have been on someones site who sells "high flow" intake components. cant remember.
Old Mar 21, 2007 | 03:10 AM
CentralCoaster
Keep in mind it'll flow whatever your motor is pulling through it.
You might get it to flow 20% better, but if the losses through the MAF are only 5% of the whole system, (filter to combustion chamber to exhaust tips), you've gained 1%.
For the money, even .01% is worth it. I left my front screen in though to keep debris out, although the MAF wires are actually pretty durable.
To Mass Air Flow screen removal
