automatics w/ nitrous?
Old Mar 18, 2007 | 10:05 PM
Slinky85's Avatar
Slinky85
Default automatics w/ nitrous?
Is it safe to run nitrous on automatics in between automatic gear changes? If I maintain WOT is everything fine. thanks
Old Mar 18, 2007 | 10:11 PM
Pete K's Avatar
Pete K
If the trans is healthy, you should be fine. The 85 model year has a smaller forward sprag and lo-roller clutch than the 87 and up units. This makes them a bit weaker. Also, the 3-4 pack is set up much looser on the earlier 700r4's. If you hurt the trans, be sure to address these things during the next refresh. Also, upgrade the reaction shell and pump while you are in there.
Old Mar 19, 2007 | 08:03 PM
Slinky85's Avatar
Slinky85
So it wouldnt hurt the engine right?
thanks
Old Mar 19, 2007 | 08:23 PM
Pete K's Avatar
Pete K
If jetted properly and you do not have a fuel or ignition, you "should" be
fine. Never any guarantees though.
Old Mar 20, 2007 | 03:17 AM
AZC4Guy's Avatar
AZC4Guy
I run a 200 shot in an auto... w/ a wicked Pete K 700R4
Old Mar 20, 2007 | 08:20 AM
Pete K's Avatar
Pete K
Thanks for the good word Steve
I finally built one for myself. Just about identical to yours but with a different 3-4 clutch pack. I never used the one that I installed in my trans. I guess I will be the test mule for it.
Got a nice 9.5 inch converter as well. As soon as the snow melts(May ) I hope to put it in.
Old Mar 27, 2007 | 10:18 PM
soultkr96's Avatar
soultkr96
automatics are all that we run in drag racing and we shoot the house down with automatics. you will never back fire the kit unless it does not make the shift before the rev limiter kicks in and saying that you have no other problems.
Jon
Old Mar 29, 2007 | 07:52 PM
Redparrot5's Avatar
Redparrot5
What about on a 92 transmission? Any advice?
Old Mar 30, 2007 | 08:53 AM
mn_vette's Avatar
mn_vette
I ran nitrous on my '93 auto. Once you get going just hold the button down until you are done with the run. It won't be a problem.
Old Mar 30, 2007 | 06:22 PM
Pete K's Avatar
Pete K
If it is the origional trans, and has never been rebuilt, the single cage sprag and reaction shell are the 2 hard parts that break the most. If the 3-4 clutch packs have allways been the weak soft part.
Old Jun 10, 2007 | 04:53 PM
NitrousSam's Avatar
NitrousSam
Default Nitrous with an Automatic
Automatic with nitrous. There are a few answers to your question and I will give you a couple of thoughts.
1. I ran a 1985 with a stock trans and spray and launched the car on nitrous and never had an issue and I got VERY greedy with the nitrous.
However, the car was essentially stock except for some minor bolt ons.
2. If your trans is weak or if you have modded your car already beyond the nitrous you may quickly find that your trans is not up to the task when you spray it.
Best of luck!
Sam
Old Jun 14, 2007 | 04:02 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Old Jun 14, 2007 | 09:47 PM
jslt1's Avatar
jslt1
Jon
Just make sure you dont hit the rev. limiter, if you do, you will lean out and fry something. Cause, thats what the rev. limiter does is cut the fuel, and then its a good chance youll hear a boom I think nos with autos is pretty cool, they are consistant as hell
Old Jun 19, 2007 | 03:37 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I've been spraying a 125 shot for several years with my stock 700r4. My chip is supposed to stiffen the shifts and it hits pretty hard. I've had no problems but I do alot of routine maintenance.
I would think the simple risk of human error (read mis-shifts and reaction tenths lost in shift gaps) would actually make automatics safer with N2O than manuals. JMO
One more thing, but the l98 has a very high rev limiter. I think it's like 9 grand or something, so you wont be hitting it, but my memory may be off so yall correct me if Im wrong. I've taken a long break from my Vette learning to stunt my crotch rocket.
Old Jun 19, 2007 | 11:01 PM
Dan Parker '96's Avatar
Dan Parker '96
I hate the automatic for curvy driving. It sucks *****.
But for drag racing and nitrous it's the cats ***. The auto willl act as a clutch and help save the components downstream (drive shaft, u-joints, etc.). The tires are the cap on the bottle. Make sure they allow enough slip to save everything in front.
As for the engine itself... in the interest of longevity you need to run the ratio pretty fat... 12:1 will be safe. You may not win a prize but you will drive back home.
Old Jun 27, 2007 | 04:39 AM
wayne lowry's Avatar
wayne lowry
With Nitrous you will need slicks, with slicks you will need a Dana 44.
Old Aug 5, 2007 | 05:10 PM
Slinky85's Avatar
Slinky85
by ratio you mean compression right? How do you change that? Heads?
To automatics w/ nitrous?
Old Aug 7, 2007 | 03:48 AM
No Go's Avatar
No Go
12-1 ratio is Air to Fuel ratio.
All the off the shelf systems will be this or richer (11-1)...unless you have modified your engine then the ratio could be off. In that case, a wide band o2 sensor is the answer found at a dyno.
You will have no problems with your plans.
Old Dec 29, 2007 | 02:00 AM
Slinky85's Avatar
Slinky85
I just got my trans rebuilt at ATI in baltimore, overseen by the owner (distant familly friend). he moved back the shift points...
no real engine mods, just full exhaust (w/stock headers)
so in summary, error free, I launch, wait till ~3k rpm hit it and hold it untill im done?
say i buy the nos kit for tpi, it will be ~12:1 AF ratio?
since my trans hits harder (rebuilt = upgrade) will my rear end go (dana 36)? or is it pretty safe back there?
I read about pcv breathers, are they breathing exhaust? or is it "clean" enough to breath under the hood without getting stuff dirty, or does it really matter? are they safe/clean to use in a dd?
Old Dec 29, 2007 | 03:36 AM
No Go's Avatar
No Go
Nitrous: That is correct...no need to let off with an automatic once underway...the beauty of the trans!
D36's are durable enough for what you are doing by far...it is the tremendous shock from high stall converter/sticky tires or a stickshift that breaks things.
Breathers...why would you change them? No performance to be gained...and you loose emission compliance besides messing up the outside of your engine (more than likely). My LT4 runs stock breather setup and turns 7000 rpm and 455 HP.
