What else when going to LT headers?
Old Mar 19, 2007 | 01:09 PM
BlackHarleyMan's Avatar
BlackHarleyMan
Default What else when going to LT headers?
I'm wondering if the O2 sensors should be replaced with new units on the new exhaust? I saw a few post awhile back talking about a 3-wire O2 sensor, but never got the full scoop on that mod. What else should I consider changing out besides the Cat?
R/Noland
Old Mar 19, 2007 | 01:19 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
When you install your headers, you should use a heated o2 sensor. This is because the headers run cooler, the unheated o2 sensor will not get hot enough to go into closed loop. I believe you only need to buy a heated sensor from any large GM car.
Hope this helps
Randy
Old Mar 19, 2007 | 02:44 PM
PBnf's Avatar
PBnf
Would this still be true if you install ceramic coated headers?
Old Mar 19, 2007 | 03:41 PM
BlackHarleyMan
I wonder if this is the reason that the 3-wire O2's are used? OR is it something more than just this cooler exhaust temps?
Old Mar 19, 2007 | 04:34 PM
tequilaboy's Avatar
tequilaboy
With an unheated O2 sensor and long tube headers it is likely that the ecm will drop out of closed loop control at idle or under very light loads.
During normal cruise the ecm should stay in closed loop even with an unheated O2.
This is only a problem if you have a poor open loop calibration at idle.
If you do wind up with problems during open loop idle, you have a few options available in order to remedy the situation.
Heated O2 sensors, adjustable fuel pressure regulators, or custom chip tuning are readily available.
A heated O2 sensor is not really a substitute for proper tuning and is really quite unnecessary with a good tune, unless idle and cold start emissions are a priority.
Old Mar 19, 2007 | 05:04 PM
vader86's Avatar
vader86
3-wire (heated) sensors are not required, and even less so with ceramic coated headers where the heat is retained inside the pipes better.
In normal operation the regular sensor would only drop out of closed loop at idle, mine hardly ever does even that.
Old Mar 19, 2007 | 05:06 PM
BlackHarleyMan
So is replacing the O2 sensor a smart thing to do when changing over to LT's or is it one of those components that hardly ever go bad?
Old Mar 19, 2007 | 05:13 PM
vader86's Avatar
vader86
I replaced mine because the car has 130K on it and I figured "why not?"
No other reason in particular, my fuel mileage was fine before the headers.
Old Mar 20, 2007 | 01:03 AM
A BirdMan Converted's Avatar
A BirdMan Converted
copper header gaskets!!!!!
Old Mar 20, 2007 | 08:45 AM
BlackHarleyMan
Made by, and where at?
Old Mar 20, 2007 | 09:37 AM
Strick's Avatar
Strick
What is the 3rd wire in a heated O2 sensor? From what circuit?
Old Mar 20, 2007 | 02:47 PM
JAKE's Avatar
JAKE
One goes to ground, the second goes to a switched 12 volt source (only hot when ignition is in "run" position) and the last one ties in to the factory 02 harness.
Two wires are white and the third is black. The two white wires are for ground and the 12 volt source; the black splices into the wire leading to the stock, single wire 02 sensor.
Jake
Old Mar 20, 2007 | 07:36 PM
VenkmanP's Avatar
VenkmanP
It would be better to wait and replace them after you have some miles on the header installation, because substances given off from the headers, sealers, etc. can hurt the O2S. It's pretty common for people to have dead O2S soon after a header installation.
In general, O2S are good for 30-50k miles.
Old Mar 20, 2007 | 11:48 PM
rebuildman's Avatar
rebuildman
OEM's went to the heated O2 sensor because it gets the engine into closed loop faster at cold start up. O2 sensor needs to be at a certain temp before it will work, unsure what that temp is, I used to know it, 600F? So depending on where you mount the sensor in the header collector and what temp it is there would determine if you need one.
Old Mar 21, 2007 | 12:19 AM
hippy's Avatar
hippy
Hope this helps
Randy
I have MANY datamaster logs that would disagree with you. I have TPiS headers and it always has gone into closed loop and the only time it comes out is when I turn the car off for a while and start it back up. There's a trick you can do without datalogging to see if your O2 is going into closed loop, right Ron?
Do you need a new O2? Depends, is your old one bad? If not then I wouldn't replace it.
Old Mar 21, 2007 | 12:46 AM
Trog's Avatar
Trog
I ran a stock O2 in my TPIS LTs for many years before going to a heated one. Didn't really make much diff... well except the heated one failed after about 25K miles & I had to replace it.
I'm still running a heated one & I also have a heated wide band on the other header now that I plug in for testing & confirmation of how my tune is holding up.
IMHO, replace the stock one w/ another stock one after a few K miles. As also stated above, fresh headers & gaskets "may" kill an already tired O2 sensor. If I had it to do over, I wouldn't upgrade to the heated, just an extra hassel & if I need one on the road, it often isn't a simple plug & play like it was. I will be fixing that shortly but it was a lesson learned to use the correct factory connectors & in the correct configuration. I now have the male where the female should be. oops
Old Mar 21, 2007 | 02:28 AM
hippy's Avatar
hippy
Tranny? Sorry, coudnt (aka Ron) resist.
To What else when going to LT headers?
Old Mar 21, 2007 | 07:59 PM
BlackHarleyMan
Thanks for all the input, now I have a much better idea of what needs to be done. I'll find the copper gaskets and just replace the stock O2's as an insurance policy. I'm sure it can't hurt anything and after 100K or so, it just makes sense!
R/Noland
Old Mar 21, 2007 | 10:04 PM
A BirdMan Converted
LT1 or L98???
Old Mar 22, 2007 | 11:46 AM
BlackHarleyMan
LT1 or L98???
This is for an L-98
