Starter Problem
Old Mar 20, 2007 | 01:45 PM
Casem1's Avatar
Casem1
Default Starter Problem
I am looking for an opinion on what I should do with my starter (on an L98 car). Sometimes when I turn the key the starter simply spins freely, then I have to keep trying until it catches the flywheel and the car starts. What causes this? Is it possible that everything is fine and the starter just needs some adjustments? Or, is there no way of knowing without removing the starter and looking?
Old Mar 20, 2007 | 03:18 PM
jfb's Avatar
jfb
The starter solenoid pushes the pinion gear into the flywheel ring gear and at the end of its stroke also forces two large copper contacts together to switch current to the starter motor. You would need to remove the starter to look at the condition of the pinion and ring gear to determine if missing teeth are the problem or if it is something else.
Old Mar 20, 2007 | 03:24 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default starter
usually there are three reasons for this:
1. there is old grease in the starter drive, and it has become
thickened and dried out with age, and needs to be relubricated.
2. The starter drive is worn out and needs to be replaced.
3. the starter brushes and commutator are worn, and the starter does
not spin up initially fast enough to throw the starter drive out to
the flywheel. a slow initial spin coupled with the other two items
means take the starter apart, clean it, undercut the micarta, put in
new brushes, change the bearings, lube it, and reinstall.
A. If it just clicks, usually it's a solenoid problem. change it, and it
should work till the rest of the starter gives out.
a self overhaul should be like $35, replacements can be upwards of $150 for a quality rebuild.
Old Mar 20, 2007 | 04:06 PM
robertt43's Avatar
robertt43
What I think your hearing is the "motor" going thru it's cycle without engageing the bendix. The motor spins and catches the Bendix which rotates on a worm type gear towards the ring gear and turns over the engine.
Old Mar 20, 2007 | 06:12 PM
Casem1's Avatar
Casem1
I love this website. Thanks guys, I will be jacking the car up soon and having a look.
Old Mar 20, 2007 | 07:24 PM
CFI-EFI's Avatar
CFI-EFI
the flywheel.
You two are showing your ages. These starters haven't used a screw out "Bendix" in decades. Rather than being thrown outward on a screw drive as a real Bendix, the starter drive is pushed outward, into the ring gear by a fork or yoke in powered by the solenoid.
It is possible the drive is hitting on the side of the ring gear, not allowing engagement, but unless the starter has been moved lately, that is not likely. Chances are cleaning the contacts inside the solenoid will fix the problem. The efforts can range from cleaning the contacts, buying a solenoid rebuild kit, buying a solenoid, on through to buying a complete, new or rebuilt starter. The above applies to the large Delco starter, since a year isn't mentioned. Probably the OE mini starters, too.
RACE ON!!!
To Starter Problem
