Wider Tires
Old Mar 20, 2007 | 11:19 PM
Danspeed1's Avatar
Danspeed1
Default Wider Tires
I'm sure this question has been asked but I can't seem to find it under search; so again here goes.
I have an 89 Vette currently running The 17in chrome ZO6 Rims with 275/40/17 tires all the way around. I am going to need a new set of tires real soon. I have the Z51 Suspension Packaged so the ride is a litte rough. (stock ride height)
So first off. Should/Can I go wider on the tires.... Like 285... maybe even 315... infact let me just ask.. whats the widest I can go on those rims.
Secondly If I go wider in the rear, whats better for the ride and handling???? Is it better to go wider in the back and less wide up front. Or just wider all the way around??? I know in the snow the thinner the better, but I will be getting snow tires next year.
Finally, can I step up to a 50 series tire instead of a 40 so I have a little more meat inbetween me and the road?
Dan
Old Mar 20, 2007 | 11:54 PM
chaos on wheels's Avatar
chaos on wheels
285's fit on 17x9.5" wheels, came stock that way from '93-'96. Some have put 315's on the 9.5", but the wheel is really too narrow for that width tire.
Lots of people put 315's on the rear (on 11" wide wheels) and 275 or 285's up front. I like wide tires all the way around, less understeer.
Good luck finding a 275/50R17. Going to a 50 series increases the height of the sidewall, and the overall diameter of the tire. That may not fit in the wheelwell.
-Jason.
Old Mar 21, 2007 | 12:50 AM
Trog's Avatar
Trog
50s if you could find them will be a lot taller tire... not good.
I've ran 285/40 on 17.5 rims & they have been fine. I'm now running 305 on 18x10.5 Z06 wheels all around & the only rub I had was minor inner fender on the rear. I had the inner plastic out a few months back & adjusted the mount holes a little & hope to have fixed that issue.
Old Mar 21, 2007 | 06:50 AM
Barbara_S's Avatar
Barbara_S
Since it's the suspension that is bothering you, you could consider a softer tire compound. Take a look at Nitto RII's. They are semi race tires, but have enough tread for fair weather driving. I liked the tire for autocrossing, but I was really surprised that they absorbed a lot of the vibration from the Z51 suspension in my car. The down side is that they may only last 10000 street miles which for me is over 2 years on my Corvette, making it worth my while. Good luck.
Old Mar 21, 2007 | 12:29 PM
rdefonce's Avatar
rdefonce
285/40's would be the hot setup for your stock-size 9.5" wide rims. Probably should have done that before getting my last set, because I see that the 285's are only a couple more bucks than 275's.
Old Mar 26, 2007 | 11:59 PM
Danspeed1's Avatar
Danspeed1
Unfortunately I had to go with the 275's again... the price difference was almost $50 per tire!!!!!
P.S. Discount tires has good prices... Falken 512's 275/40/17 $104 a piece!!!!
DG
Old Mar 27, 2007 | 03:41 AM
LT1CORVETTE's Avatar
LT1CORVETTE
DG
Nothing wrong with 275's on all four. Check out the falcon azenis next time if your looking for a discount tire. Good bang for the buck. Had them on my street miata for a while.
To Wider Tires
