Replacing head gaskets - help please
Old Mar 21, 2007 | 10:17 AM
jimmers's Avatar
jimmers
Default Replacing head gaskets - help please
My head gaskets is leaking, so in about a week I will need to replace it. I'm just curious as to where would be the best place to get the gaskets and bolts from. Corvette Central sells an intake gasket set, but I dont know if its good or not. http://www.parts123.com/parts123/yb....Z5Z5Z50000050F. This may be a dumb question, but my intake gasket right now has a sealant like substance for a gasket. Is that what the sealant in the kit is for? I can only find head gaskets for a ZR1 on Corvette Central, not for an L98. I'd prefer not to go to the dealer for any of this, since i'm assuming it would cost alot more.
Also I remember reading that you can get reusable head bolts, but I cant find where.
90 L98
Thanks everyone!
Old Mar 21, 2007 | 10:24 AM
Pete K's Avatar
Pete K
90 L98
Thanks everyone!
The factory 90 head bolts are not torque to yeild bolts. You absolutely may(and should) reuse your origional bolts. They will need to be cleaned of the old thread sealnt that the factory applied. Liquid teflon is my preferred sealant. I suggest that you use it upon reassembly.
Head gaskets are easy as well. 7733pt-2 Fel-pro gaskets are perfect for your needs. $15 or so each, and available anywhere that sells fel-pro.
Old Mar 21, 2007 | 10:53 AM
curtismoff's Avatar
curtismoff
You should have your heads checked out.while they are out.9 out of 10 times something made the gasket fail.
Old Mar 21, 2007 | 11:11 AM
jimmers's Avatar
jimmers
Thanks, I was under the impression I couldn't resuse the bolts. Thanks for the part number of the gaskets, you made it easier for me!
Old Mar 21, 2007 | 11:12 AM
jimmers's Avatar
jimmers
Ya thanks for the heads up. My dad works at a machine shop so he will check them out.
Old Mar 21, 2007 | 01:59 PM
LTxDave's Avatar
LTxDave
You can reuse bolts that aren't torque to yield, but if I had a head gasket failure I would replace the bolts as well as having the heads checked.
To Replacing head gaskets - help please
