Making my fans come on
Old Mar 21, 2007 | 10:50 AM
curtismoff's Avatar
curtismoff
Default Making my fans come on
Is there any way to make them come on early.94 auto.When in traffic my car seems to run a little hot 225 seems hot to me.If I turn on the a/c both fans come on and it cools down to 210 right away.Can someone post a link to help me out
Old Mar 21, 2007 | 10:54 AM
billybonesmusic's Avatar
billybonesmusic
http://www.jegs.com/webapp/wcs/store...0002_744377_-1
these you can adjust
Old Mar 21, 2007 | 10:57 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
search tech section: install a fan on/off switch...
Old Mar 21, 2007 | 11:00 AM
dchildress's Avatar
dchildress
When I bought my 94 LT1 6 speed, the fans were hot wired on all the time. I ran a switch up to the dash to control them as I wish. On mine, the relays are hanging on the driver's side of the radiator shroud. Splice into the green wire and dark blue wire, run them thru a switch, then ground the line. Splice, DO NOT CUT, the green and blue wires. My fans work normal when my switch is off and they both run all the time when on.
Old Mar 21, 2007 | 11:04 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
225* is not too hot. The main fan should come on @226* anyway.
Old Mar 21, 2007 | 02:33 PM
dchildress's Avatar
dchildress
I agree. In the summer with the A/C on in 98 degree heat in traffic I have seen 242deg...THAT IS HOT!!!!! I found tons of leaves in my radiator shroud as the problem.
Old Mar 21, 2007 | 03:38 PM
STL94LT1's Avatar
STL94LT1
If you have a laptop with a serial port. Buy an AKM cable and Tunercat software. Then reprogram the fans yourself.
http://tunercat.com/tnr_desc/do_tc.html
http://www.akmcables.com/ccard.htm
Old Mar 21, 2007 | 03:51 PM
drazmo's Avatar
drazmo
i have the same "problem" on my 94 automatic...my dad and i hooked up the scanner and found that the temperature guage in the dash actually read about 15 degrees hotter than the true temperature. after reading the manual it appears that the fans were going on at the correct temps. even though this is the case, i WOULD feel much better if the car ran a little cooler.
anyone try a 160 deg thermostat? is it any better?
Old Mar 21, 2007 | 05:07 PM
dchildress's Avatar
dchildress
The low temp thermostats do not really do anything to help you. With an LT motor you NEED to keep temps in the 185 to 205 range for a nice, complete burn. Check the sticky at top of forum page on performance items that work....maybe FAQ.
Old Mar 21, 2007 | 05:08 PM
enventr's Avatar
enventr
Do a search-There are pages of arguments about 160 vs. a 180 stat
To Making my fans come on
