Driver's window not responding. What to suspect?
Old Mar 21, 2007 | 04:05 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Default Driver's window not responding. What to suspect?
What's a good way to diagnose a window that won't move at all? Already checked fuses.
Old Mar 21, 2007 | 04:08 PM
macfos's Avatar
macfos
My passenger's side stopped working, but the driver's side worked, fuses were good. There ended up being a bad ground on the regulator. A little solder and it was fixed.
Macfos
Old Mar 21, 2007 | 04:09 PM
86PACER's Avatar
86PACER
Swap window switches. If it now works, the switch is bad.
macfos's Avatar
macfos
Also, if that is not it, the motor may have bound up... give it a good whack with a solid metal object and try that. It may free up the motor. I have seen it work before on older vehicles.
Macfos
Old Mar 22, 2007 | 02:39 PM
JAKE's Avatar
JAKE
Yep, that's how I diagnosed the window problem on my 86.
Jake
Old Mar 23, 2007 | 01:03 PM
Black-Cloud's Avatar
Black-Cloud
Cruising
Default Bad window Switch
My 90 had right side trouble. Yes bad switches. Plus on the 90 I had a hard time finding the switches.
Good luck.
Old Mar 23, 2007 | 01:39 PM
93-383's Avatar
93-383
I had a similar problem on my 93 what sucked was it was the motor that was bad and thoese things are a pain to change out
Old Mar 23, 2007 | 06:44 PM
JAKE's Avatar
JAKE
Good luck.
I ordered a replacement from my local chevy dealer and it only took a couple of days to get it.
Jake
To Driver's window not responding. What to suspect?
