96 Headlight Switch Wiring
Old Mar 21, 2007 | 11:53 PM
z28redline's Avatar
z28redline
Default 96 Headlight Switch Wiring
I'm looking for a wiring breakdown of the headlight switch on a 1996 c4. I'd like to know color/function if anyone could provide it. My reason for the request is that I just purchased this car and I need to add daytime running lights to make it legal to drive in BC. I am getting a GM Y-body manual which I think would contain that kind of information but will not recieve it in time to meet the deadlines for importing it into Canada. Thanks in advance.
z28redline
Old Mar 30, 2007 | 05:41 PM
z28redline's Avatar
z28redline
Still looking for this information if anyone has it.
z28redline
Old Mar 30, 2007 | 09:34 PM
QB93Z's Avatar
QB93Z
Default Ready to help
I have the Service Manual open to the Headlights and Fog Lights page, what is it you need to Know? Jim
Old Apr 2, 2007 | 07:15 PM
z28redline's Avatar
z28redline
I'm just looking to find out which of the wires triggers the parking lights?
z28redline
Old Apr 2, 2007 | 07:26 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Web Electric sells a plug-in one for about $40. Plenty of members have bought it:
http://www.webelectricproducts.com/
Old Apr 2, 2007 | 08:27 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Let's try the C4 Tech section also.
Old Apr 2, 2007 | 10:05 PM
QB93Z's Avatar
QB93Z
The Service Manual shows a Brown wire going to the parking lights. Good Luck. Jim
Old Apr 4, 2007 | 03:24 PM
z28redline's Avatar
z28redline
Jim, that was what I was looking for. Do you happen to know which one triggers the low beam headlights?
IrishMac, I couldn't find anything in the tech pages to help me, do you have a link?
z28redline
Old Apr 4, 2007 | 04:40 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Sounds like more trouble than it's worth digging around with those wires.
tobijohn gave the best answer:
Once at that site:
Click on "Daytime Running Lights"
Second one down "Corvette Daytime Running Lights Module"
Click on "Click here for more detail"
DRL-1C4 Daytime Running Lights: $39
Click "Add to Cart"
Old Apr 4, 2007 | 04:42 PM
QB93Z's Avatar
QB93Z
z28redline
There is a yellow wire from the Headlight Switch to the Headlight Dimmer Switch. Then a TAN wire to the low beam filaments and a LT GRN wire to the High Beam Filaments.
Good Luck, Jim
Old Apr 4, 2007 | 05:31 PM
z28redline's Avatar
z28redline
Once at that site:
Click "Add to Cart"
I have looked in to this option but there are a couple of problems. 1)It only turns on the front two turn signal lights not all of the parking lights so it won't pass the inspections. 2)It involves cutting up the wiring harness in multiple locations which I am trying to avoid.
Jim, just to clarify, do the tan and light green wires come out of the Headlight switch or the dimmer switch?
Sorry for all the questions,
z28redline
Old Apr 4, 2007 | 05:54 PM
tobijohn's Avatar
tobijohn
Bench Racer
Wow, I thought it just plugged in with minimal cutting involved. Well, forget about that. If Jim wants to tell me which pages in the FSM he's referencing, I'd be happy to scan it and either post or email it to you...
Old Apr 4, 2007 | 06:14 PM
z28redline's Avatar
z28redline
That would be great if you could. I'm trying to remove the pins from the factory connector and make a secondary harness with a relay to run the daytime running lights. I was planing on posting my completed project when I'm done.
z28redline
Old Apr 4, 2007 | 06:26 PM
tobijohn's Avatar
tobijohn
Bench Racer
z28redline
Well, not one to sit idly by, I actually got out my 96 FSM and looked at the Table of Contents. On page 8A-102-0/1 there's a schematic of "HEADLIGHTS: DAYTIME RUNNING LAMPS T61 (CANADIAN ONLY). Might this be of use to you? Or do you want the regular schematics? Or both?
Old Apr 4, 2007 | 06:31 PM
tobijohn's Avatar
tobijohn
Bench Racer
There are also schematics for "EXTERIOR LIGHTS WITHOUT DAYTIME RUNNING LAMPS (DRL) ...
Old Apr 4, 2007 | 07:06 PM
RollaMo-LT4
Well, I too thought it was just a "plug n play". I assumed the purpose of this part was to allow a C4 to pass inspection in Canada. That's what I get for jumping too conclusions, and not paying attention more.
If that's not the case, exactly what good is it.........
Old Apr 4, 2007 | 07:20 PM
z28redline's Avatar
z28redline
I would love to have just the wiring diagram for the headlight switch & exterior lights without DRL. The DRL wouldn't be nesscary but if it's easy to get I'll take a copy of that too.
z28redline
To 96 Headlight Switch Wiring
Old Apr 4, 2007 | 07:51 PM
tobijohn's Avatar
tobijohn
Bench Racer
z28redline
PM me your email address. Do you know what your ISP's maximum file attachment size is?
Old Apr 4, 2007 | 08:31 PM
tobijohn's Avatar
tobijohn
Bench Racer
Ah, forget about an email address. Here they are. Depending on your browser, just right-click and select Save Target As and download to your hard drive. Good luck:
Old Apr 4, 2007 | 08:32 PM
tobijohn's Avatar
tobijohn
Bench Racer
And here are the schematics for the OEM DRLs:
