Violent Shake
Old Mar 22, 2007 | 03:26 PM
BlackVette00's Avatar
BlackVette00
Default Violent Shake
When I drive my 93 vette 6 speed about 80+, while giving it gas it shakes, but then while im goin 80+ and cruise not touching the gas pedal its smooth riding, what could be the problem?
Old Mar 22, 2007 | 03:47 PM
Mojave's Avatar
Mojave
Check your u-joints. A vibration under acceleration only could be a bad u-joint (could be in driveshaft or half-shafts).
Old Mar 23, 2007 | 12:13 AM
IndianaJef's Avatar
IndianaJef
Could this be a broken or loose motor mount? Something to check.
Old Mar 23, 2007 | 01:40 AM
BAM92's Avatar
BAM92
Are you in 6th or 5th gear when you are accelerating?
Old Mar 23, 2007 | 09:59 AM
sami85L98's Avatar
sami85L98
Darn this is the same problem i got on my lexus DD, it shakes while accelerating at low speed but it smoothed out once i attained certain speed, but even while cruising on hwy it still shakes for a slpit sec than rides smooth, according my home boy mechanic, it does b/c one of cyl has problem and could cause overheating and ultimately damage Cat converter. Is this same symton u have, when it shakes i thought could be some suspension problems, even at idle with gear in park, still it shakes for a split sec. If u have same symptons than right now my mechanic working on it, i let u know when we solve problem.
Old Mar 23, 2007 | 10:02 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Check the driveshaft u-joints
Old Mar 23, 2007 | 01:07 PM
all show and more go's Avatar
could be the wheelbearing,im in the process of replacing mine.
Old Mar 23, 2007 | 02:00 PM
BlackVette00
if it helps any, I do hear squealing noise, not at idle only in low gears like in the back, from the seats back, makes a continuos noise
To Violent Shake
