90 HVAC vacuum source
Old Mar 24, 2007 | 03:29 PM
1990Redcoupe's Avatar
1990Redcoupe
Default 90 HVAC vacuum source
Does anyone know how the HVAC programmer connects to the vaccum source ? ( 90 TPI ) The FSM does not specify the location so I traced out the underhood vacuum lines. I can see where the vaccum is taken from the plennum and goes to the storage tank and cruise control but I cannot find the point where it feeds the HVAC programmer.
As you may have guessed my heater is stuck on defrost. I can hear the relays clicking on the programmer when I select various modes so I'd like to verify there is vacuum before I dig deeper.
Thanks...
Old Mar 24, 2007 | 06:05 PM
VtVette's Avatar
VtVette
Of the two ports on the rear right corner of the upper plenum it should be the rear one. The diagram below is for a '91. Yours should be the same. the vacuum line leading to the port should be black.
hope this helps,
Old Mar 24, 2007 | 11:28 PM
pablocruise's Avatar
pablocruise
Keep in mind that in my pic there the hose is missing the 90* elbow, and the check valve on the end of it.
Old Mar 25, 2007 | 07:00 PM
1990Redcoupe
I found the hose. It had came off the check valve and fallen behind the distributor. Thanks for your help.
To 90 HVAC vacuum source
