I know, that was my thinking, too. So there must be a reason why they are doing it... and perhaps the rubber belt survives better at high sustained RPM.
Cam belt drives for Chevy V8's have been around for a while in drag racing.
Here is an image of the RCD piece, I remember thinking that it was racy to
see the exposed belt under a hood (and I still think this is one of the visual
go-fast parts that a non-race vehicle can use for impact.)
I would have thought belt drives would have been in use for a while in
circle track racing - are you saying that they have only recently been adopted?
All of your high end engines will use the belts if they can/want. The Jesel belt drive is the most commonly used but others are coming out. It's freaky to think that a belt works but it actually works very well and has many advantages over anything else out there. For about $800 you can have one on your first gen sbc. Since there is only a dust cover (and sometimes nothing) you can adjust anything you want on the camshaft without opening up the engine and it frees up some hp.
If any of you guys every worked on snowmobiles and saw the abuse that a drive belt takes, albeit a larger belt than a timing belt, you'd realize those things are pretty damn stout.
I work with timing belts at my job and those little turds can take hella lot of abuse.
belts are not weak... they are used in all sorts of applications.
It's just different for the SBC. I am wondering if oil control is one of the reasons they did this... think about it, they could seal up the front of the engine, removing leak points... just a thought.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You actually have more leak points using the belt, because now you need a cam seal.
They are used because they transmit far less crankshaft harmonics to the valvetrain. Cup engines need all the help they can get in the valvetrain department.
SJ
In addition to the harmonics that DLM 18 mentioned, the ease of cam timing adjustment assists in finding that last bit of HP faster. No covers to remove, just grab the wrenches and give it a tweek.
SJ
I watched Pinks and a guy raced a '70 or '71 with a 454? engine. It was the vette designed for drag racing. Anyway the vette beat the guy he was racing but it broke down after the race and the driver said he lost his timing belt. I agree with the first post - I thought it would have used a chain. A friend told me belts are easier to adjust at the track or something.
