Change oil light
Old Mar 26, 2007 | 12:15 PM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
Default Change oil light
I had my oil changed less than 1000 miles ago. The change oil light is now on. Anyone got a clue? '91 L98 A4
Old Mar 26, 2007 | 12:27 PM
clf93lt1's Avatar
clf93lt1
http://forums.corvetteforum.com/show...ange+oil+light
Old Mar 26, 2007 | 12:32 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Don't tell me the Search function on this forum is on the fritz again??!!
Larry
code5coupe
Old Mar 26, 2007 | 12:34 PM
clf93lt1's Avatar
clf93lt1
no thats where the link came from.
Old Mar 26, 2007 | 09:08 PM
carlton_fritz
This works on a '91 too? I couldn't tell you what a '93 looks like.
Old Mar 26, 2007 | 09:09 PM
carlton_fritz
Larry
code5coupe
It's called being in a big hurry and not knowing when I will get back. It was faster for someone to post that link.
Old Mar 26, 2007 | 09:28 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yes except the '91 has a different button, I think instead of eng/met, you have range or something like that.
Old Mar 26, 2007 | 11:11 PM
Steel Blue 91's Avatar
Steel Blue 91
Tech Tip...................
https://www.corvetteforum.com/techti...=255&TopicID=2
Oil Life Monitor reset (Change Oil Light) 1990 - 1996 -- 1 of 1
Date Published: 2003-12-11
Seeing as this question is posted every so often, I thought I would put it in the tech tips for easy access. It works both on my 91 and a friends 95. 1. Turn the key to the "ON" position, but don't start the engine. 2. Press the ENG/MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG/MET button again. 3. Within five seconds, of Step 2, press and hold the RANGE (1990-1991) button or the GAUGES (1992-1996) button on the Trip Monitor. The CHANGE OIL light will flash. 4. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out. When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds. If it doesn't reset, turn the ignition "OFF" and repeat the procedure. If you remember to follow the procedure after every oil change, you should never see that light again.
Old Mar 27, 2007 | 02:46 PM
carlton_fritz
That helps. I couldn't find a "gauges" button anywhere.
Old Mar 27, 2007 | 10:26 PM
clf93lt1's Avatar
clf93lt1
https://www.corvetteforum.com/techti...=255&TopicID=2 its in the link
To Change oil light
