Original 1985 Corvette Piston Specs?
Old Mar 26, 2007 | 04:53 PM
DF's Avatar
DF
Default Original 1985 Corvette Piston Specs?
Hi guys, I am getting my engine rebuilt and we are trying to find a replacement piston that is the same as the original specs, the ones that were in there were not original and we can't find all of the specs. Would anyone know the following for an '85?
Number of valve reliefs
Compression distance
Wrist Pin Offset
Also my mechanic found a piston that ups the compression from 9.1 to 9.4, would this not cause any issues with the stock ecm settings?
Thanks!
Old Mar 26, 2007 | 06:37 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
The 85 is a forged piston and has one valve relief only. The other measurements should be the same on any stock type Chevy 350 piston.
Old Mar 26, 2007 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
Number of valve reliefs One.
Compression distance 1.560".
Wrist Pin Offset Not a commonly used spec. .060"?
Very similar to or the same as the SpeedPro/TRW L2417F
Thanks!
I'd go for even slightly more compression of it can be done cheaply and easily. Keep your eye on the quench area. That could solve several problems.
RACE ON!!!
Old Mar 27, 2007 | 10:53 AM
DF's Avatar
DF
Thanks guys!
Old Mar 27, 2007 | 11:51 AM
DF's Avatar
DF
Would 0 offset be a problem?
Old Mar 28, 2007 | 01:41 PM
DF's Avatar
DF
Any ideas?
To Original 1985 Corvette Piston Specs?
