9.7:1 compression with FI
Old Mar 26, 2007 | 09:28 PM
Phatoscar's Avatar
Phatoscar
Default 9.7:1 compression with FI
My car was just rebuilt and the compression is 9.7:1 is that so high to do a turbo on supercharger? the engine is bored over and is now a 355 and has forged pistons with clevete rod bearings and a slightly bigger cam.
Old Mar 27, 2007 | 09:56 AM
mn_vette's Avatar
mn_vette
If you are planning on running low boost, under 10psi intercooled, then you should be fine. Remember the LT1 engine runs 10.5:1 stock and people supercharge those without issues up to 8psi.
If you really want to go all out I'm sure doing a piston swap wouldn't be too bad if you were planning on running 15+psi.
Old Mar 27, 2007 | 11:22 AM
Phatoscar's Avatar
Phatoscar
Old Mar 27, 2007 | 11:47 AM
LTxDave's Avatar
LTxDave
Swapping to larger chamber heads is also a relatively painless option if you are looking to lower the compression.
To 9.7:1 compression with FI
