race seats
Old Mar 27, 2007 | 12:23 PM
excessive81's Avatar
excessive81
Default race seats
what is out there that will fit in these cars. i have seen mention of side mount and bottom mount. looking to sale my stock seats and hopfully pay for lighter race seats with the money
Old Mar 27, 2007 | 02:32 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
I Have Ultra Shields.
Made to order.
Send shoulder and waist sizes.
These are serious race seats, not a fashion statement.
Matt383
Old Mar 27, 2007 | 04:02 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Made to order.
Matt383
Thanks for posting that. How many did you get and how much were they? Tell us about them.
Old Mar 27, 2007 | 04:27 PM
Matt383's Avatar
Matt383
Found CF member that has a racing equipment web site.
Dave whittle: http://www.whittlesperformance.com/
Anyway Dave helped me out.
Aluminum seats.
Made to fit your waist with wrap around shoulder supports.
That's why they need your measurements
I weigh 240 lbs and wear a size 60 sport coat. 38" waist
(I used to be a powerlifter)
So a seat that fits was very important.
They come with a denim like cover that has padding.
So you can wash them.
I had them welded into my car.
You can have them fitted to existing mounts but if you are a seriuos racer those mounts will rip right out.
What sold me was there was a guy that had these seats in his Outlaw Car. He rolled it seven times.
He sent a picture of his Ultra Shield seat back to the manufacturer after the accident.
They were the only thing that didn't have a bend or dent.
They weigh 15 pounds.
I had mine powder coated black. Didn't want that shiny metal showing in the back.
I bought two.
Matt383
Old Mar 27, 2007 | 04:52 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Aluminum seats.
Can you explain further? I'm trying to figure out what you meant.
Since you can't weld fiberglass, and the C4 floor pan is 'glass...and any roll cage will be made of steel and you can't weld aluminum to steel.....
Perhaps you had mounting brackets welded to a cage, to which the seat then bolted??
Larry
code5coupe
__________
I ain't easily impressed....
Old Mar 27, 2007 | 05:05 PM
Matt383's Avatar
Matt383
__________
Ok.
I had them installed by Alston Race Car Engineering.
847-395-3500
Call and ask for mike.
Ask mike how he did it if you want the exact pin point overview on how the heck he got em in there!
Alston Race cars is very well known in the pro ranks of NHRA.
I am sure special brackets were made for the car.
There are metal plates under the floor pan the seats are connected to.
And yes they are mounted to the roll cage which is made out of Chrome Moly by the way.
Once the NHRA tech guys see the Alston plate they know it was done right.
Matt383
Old Mar 27, 2007 | 05:07 PM
rocco16's Avatar
rocco16
What exactly do you have in mind? "Race" seats can mean anything from the hard core aluminum-shell-and-not-much-else that Matt described; to rigid 'glass or plastic shells with upholstery; to the reclining, bolstered, adjustable, (even leather-clad) rally seats so popular these days.
If this is a street car that they are going in, then you will probably want the latter, rally seat. The Corbeau A4 is a good example of this, and is the only Corbeau guaranteed to fit into a C4. Another option for this style of seat are the many, many brands coming over from the Far East at this time; you'll recognize them because they look really cool and only cost about $150 -$175 each. Most of them will fit into a C4, but finding mounting brackets is up to you.
These seats use a bottom mount, where the rigid style use side mounts. The rigid styles are not (generally) adjustable; you put the seats exactly where you want them, fabricate the mounts to hold the seat in that location, and live with it forevermore. The rally-types are almost always fore/aft adjustable and have seatbacks that are adjustable for rake/angle. Only the more expensive seats...like the Corbeaus...have seatbacks that will tilt forward to allow access into the back of the car.
A search should turn up lots of threads on this subject, with some very good advice from those who have tried it and from those who have successfully accomplished the task.
Good luck!
Larry
code5coupe
__________
Old Apr 3, 2007 | 04:36 PM
excessive81
yeas i want adjustibale ones
Old Apr 3, 2007 | 05:19 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Contact forum vendor Hardbarusa.com
He sells seat rails that are all bolt-in.
I let him use my car for prototyping.
Old Apr 3, 2007 | 06:11 PM
excessive81
all i see listed is for c5 seat mounts i am working on my 90....i know my pic is of my c6!
Old Apr 3, 2007 | 06:19 PM
BrianCunningham
He's got them in stock.
Trust me, the guy's a personal friend, and that's my car in the photo
Old Apr 3, 2007 | 06:26 PM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
Yes, we have a C4 seat rail set in stock for immediate delivery. We make them for C4/C5/C6/C6Z
Gary Hoffman
603-682-8073
Old Apr 3, 2007 | 06:52 PM
excessive81
will these work. seem to be same as the forza set dim. will they work with you brakets
Old Apr 3, 2007 | 08:13 PM
chad89's Avatar
chad89
Does anyone know if the "wide" Corbeau A4 will also fit in a c4.
Old Apr 4, 2007 | 02:36 AM
ninetyfivevette's Avatar
ninetyfivevette
I have the A4 in one of my other cars and I am not terribly happy with them (actually trading them for a different seat Friday). One of my major gripes is the lack of real back support in the padding, so the low back gets sore after a relatively short time period. There is also a hog ring that I can feel right in the middle of my spine- only a matter of time before that wears through the fabric. The seat recline mechanism is also really weak. Going over bumpy roads has the seat back moving all over the place, which is not a trait found on a quality "race" seat.
Old Apr 4, 2007 | 07:34 AM
GS348's Avatar
GS348
Default Yes
The picture you posted are the FX1 Pro's. These seats will fit b/c they are what I have in my GS. The seat rails work great (once you put them in the correct way....operator error). I also went with their 3" 5 pt harness. I have been very pleased. Contact Corbeau, they'll give you a list of dealers in your area. Good luck....Chris
To race seats
