Question for PeteK
Old Mar 27, 2007 | 03:29 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default Question for PeteK
Pete, my 400 flexplate on my 383 has rubbed two slots in my dust cover. Is there another cover I can use that will clear the bigger flexplate? Thanks once more.
Old Mar 27, 2007 | 08:27 PM
Pete K's Avatar
Pete K
That is a good question. I have not yet run across that problem. The aftermarket has a plastic cove that I assume will work. You can alter the plastic one with a heat gun if it were close in spots.
Old Mar 27, 2007 | 10:41 PM
todd_vette's Avatar
todd_vette
I had to get a metal cover and beat it outward from the inside with a picking hamer then flaten out the divits from streaching it with a slotted hammer on an anvil....Old steel body work tools. It still has noticable bumps in it though, but it will streach the metal enough to clear.
Old Mar 27, 2007 | 11:23 PM
Midnight 85
I saw the plastic one on ebay but since Vette2Vette is right here in town I'm going to get another aluminum one and do what todd_vette87 suggested. Thanks to both of you.
Old Mar 27, 2007 | 11:34 PM
todd_vette's Avatar
todd_vette
USE THE TIN/STEELE cover NOT aluminum...Aluminum is a little harder to work unless you are used to it...It needs carbonized to soften it to strech and not crack...The tin one will strech some with-out that worry.
Old Mar 28, 2007 | 02:45 PM
CFI-EFI's Avatar
CFI-EFI
How about a stock 400 converter cover?
RACE ON!!!
Old Mar 28, 2007 | 05:28 PM
Midnight 85
RACE ON!!!
That was my first thought, I could be wrong but I don't remember the 700R4 being used behind a 400. According to Summit, Jegs, etc. the dust cover for a turbo 350-400 is different than the 700R4. I got another cover today from Vette2Vette and have already "modified" it to work. (creative use of ballpeen hammer)
Old Mar 28, 2007 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
The 700R4 was never offered behind a 400, yet you were able to use the flexplate. I think probably some "creative drilling" may have resulted in a better looking end product, but either way, your problem is solved.
RACE ON!!!
To Question for PeteK
