" which distributor shaft diameter do i need? "
Old Mar 29, 2007 | 04:49 AM
sxyvet's Avatar
sxyvet
Default " which distributor shaft diameter do i need? "
hi there guys,
i want to replace my 1991 L98 engine distributor gear which i might add is the standard chev corvette distributor but with the hypertech ignition module/with cap and was wandering please what size diameter shaft i need when buying new gear please?
it will be to suit comp cam hydraulic roller cam!!!
there are three sizes apparently, .427", .491", .500 " which one is it please?
also there are differnt brands some expensive some cheap!
starting range price for a crane cam gear, # 11979 .500", 11990 .491".
these crane cam gears are made out of silicone alloy/bronze, will this be ok to use please with a hydraulic roller cam?
any reccomendations/help and advice please guys!
thanks very much again guys
cheers
glen
Old Mar 29, 2007 | 07:31 AM
Pete K's Avatar
Pete K
Old Mar 29, 2007 | 01:19 PM
sxyvet's Avatar
sxyvet
Default thanks!!!
hi pete k,
how are ya!
thanks for ya help!
so would the new alloy/bronze dist gear be ok to use please?
cheers
thanks
glen
Old Mar 29, 2007 | 04:30 PM
Pete K's Avatar
Pete K
The dist gear should match the cam gear. If you are buying a new cam, consult with the cam manufacturer for the correct answer.
To " which distributor shaft diameter do i need? "
