Identifying mods
Old Mar 29, 2007 | 07:19 AM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
Default Identifying mods
I bought my '91 A4 on December 30th. I don't know much about mods. After reading the thread about being satisfied with stock L98 power, I find that I don't have any of the issues people complain about concerning the L98 being slow. I do know I have flowmasters, 160 degree thermo, K&N and a new chip. Would that make that much a difference or do I probably have mods I can't recognize? Who could recognize them?
Old Mar 29, 2007 | 07:27 AM
Red Tornado's Avatar
Red Tornado
nope, they won't much of any difference you can tell. you don't have a baseline to compare it to. out of those mods, only the chip could make a little difference -- and that's only if it's a custom chip (as opposed to cookie cutter rip-off's hypertech, etc.).
its more likely than not that if any real mods were done, that info would have been passed on to you. do you still ahve the shorty factory exhaust manifolds? if you've got long(er) tube headers, that's one clue that more than that may have been done (cam, heads).
so if you're happy, then that's all that matters. me, i wasn't happy and the vette was my first V8 i ever had in 25+ years of driving. was it actually slow? no, but it was alot less than i expected out of the "venerable" corvette. six months was more than i could take, it had to be fixed yesterday rather than tomorrow, if you get the drift.
so that tells you i think stock baseline C4's are inadequate in terms of acceleration, and that certainly goes for the LT1 as well which is in no way off the plate in this discussion.
Old Mar 29, 2007 | 07:53 AM
carlton_fritz
I do know that the chip was purchased at The Last detail. A Corvette shop next to a Corvette dealer in Atlanta. I don't know about the exhaust manifolds. I may have to have my mechanic look. I don't know much about what stock looks like. I only know about the minor mods I have due to the receipts still being in the glovebox. I got the car from a dealer. Guess they didn't know that much about it either. People claimed the L98 was weak over 3500 RPM. Mine isn't. I also heard complaints about 40-60 power. Mine will throw you back into the seat(not real hard, but hard enough) when the gas is mashed. Seems to me that there must be some mod I don't know about.
Old Mar 29, 2007 | 08:29 AM
Red Tornado
the gages are notoriously inaccurate, so your rpms could be off as much as 500. L98 power drops off significantly at about 4,000 and hits a brick wall at no more than 4,500. what you're describing sounds pretty much stock. i think you'll find out that's the case.
Old Mar 29, 2007 | 09:04 AM
madman91's Avatar
madman91
i have the same "problem". my 91 l98 auto runs side by side c5s all day. and there is supposed to be 100 pony diff. at the strip they only started to pull on me at about 75mph. so i do think you can have unknown mods when getting the car from a dealer. just my opinion.
Old Mar 29, 2007 | 09:14 AM
Red Tornado
if you really want to know, you probably should just get it dynoed. that will help isolate it all to the car.
cost is usally about $50-$80 for 3 passes.
because comparing anyone at the track vs. each other in many cases has more to do with the driver than it does the car.
Old Mar 29, 2007 | 09:50 AM
Caboboy's Avatar
Caboboy
You better not let whatshisname hear you say this Brad
He's got the fastest car on the forum ya know..........
Old Mar 29, 2007 | 10:03 AM
Red Tornado
Hey Tim, howzitgoin my man
Old Mar 29, 2007 | 10:08 AM
vader86's Avatar
vader86
A dyno graph will tell you if anything serious was done to the engine without your knowledge.
Old Mar 29, 2007 | 01:55 PM
carlton_fritz
Mine was pulling pretty good over 5000rpm.:o Then it shifted and really pulled.
Old Mar 29, 2007 | 02:00 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Only the PO would know....
Larry
code5coupe
__________
I ain't easily impressed....
Old Mar 29, 2007 | 02:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Some things to (relatively) easily check for:
-is the frisbee gone from the front of the WP pulley?
-does it have the stock front Y w/ the two pre-cats?
-does it have a hi-flow cat?
-does it have underdrive pulleys?
-does it have 1.6:1 RRs (pull the LH valve cover to see)?
-does it have an AFPR?
-does it have 3.07 gears?
-does it have a stock TC (1,500rpm stall)?
-does it have a shift kit (very hard & fast WOT shifts)?
Other than some dyno pulls (to see if any serious internals have been done) take it to the drag strip and record trap speed, ET, air temp, RH and launch weight. From trap speed & launch weight we can calculate CHP, with air temp & RH we can normalize for weather conditions.
To Identifying mods
