Cat converter ??
Old Mar 29, 2007 | 08:37 AM
macfos's Avatar
macfos
Default Cat converter ??
Are hi flow cats worth the money? I have a 94 LT1 w/ 98k.
Do they need to be changed? Will it really do anything?
Cause any problems??
Thanks.
Old Mar 29, 2007 | 09:38 AM
lt4obsesses's Avatar
lt4obsesses
Old Mar 29, 2007 | 09:56 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Thanks.
YES! but some carry outrageous prices. Shop around, you can pay $30 up to $300. It's one of those things where you DON"T always get what you pay for.
Old Mar 29, 2007 | 10:03 AM
vader86's Avatar
vader86
No, not on an LT1. Your cats are pretty good in comparison to the L98.
I would not change them until/unless you go to longtube headers, in which case you'll probably have to for the headers to fit, or if you are having problems with the car that might indicate a clogged cat (loss of power).
Old Mar 29, 2007 | 12:23 PM
macfos's Avatar
macfos
Catco
FlowMONSTER
Magnaflow
I don't think there is anything wrong with them, but they are REALLY rusty and I think there could be a leak. Brittle rusty is some places.
If I have to replace them, I want them to be AS good or BETTER than the stock LT1 coverters.
Any brands, advice? The price range is crazy... $35 and up.
Thanks.
Old Mar 29, 2007 | 01:58 PM
BADDUCK's Avatar
BADDUCK
I used Magnaflow (Carsound) on my L98. Catco has a good rep. Check eBay there are usually better prices there. The $35 unit may be fine but you may need to weld them on. If they are brittle rusty outside they could be pretty crappy inside. I replaced mine at 48K. Make sure to leave you O2 sensors.
If you don't mind take a minute and fill out your profile.
Old Mar 29, 2007 | 02:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If your LT1 is stock at 300chp you need 660cfm of total exhaust flow or >330cfm per side and so per cat. If you plan to mod your LT1 I suggest looking for ~450 cfm of flow from each cat.
So, when selecting a cat, look for:
->330cfm flow
-fit to the front Y & in the space available
-best price
Old Mar 29, 2007 | 04:21 PM
macfos's Avatar
macfos
I have found the MagnaFlow universal on Ebay for $65 each. I don't mind welding them on, in fact I would prefer that.
Are these ok? Good price?
Thanks.
Old Mar 29, 2007 | 04:29 PM
macfos's Avatar
macfos
Default Also...
What about these:
http://flowmonster.com/mm5/merchant...._Code=metallic
They have a metallic substrate instead of the ceramic at a good price, but never heard of them until I started looking.
Thanks.
Old Mar 29, 2007 | 04:52 PM
STL94LT1's Avatar
STL94LT1
What about these:
Thanks.
Those look similar to my Dynatech PowerCats, and are cheaper. That's the cheapest I've seen a metallic substrate bullet cat.
Old Mar 29, 2007 | 06:48 PM
macfos's Avatar
macfos
Ok,
So here is the stupid question. What is the size that I need? I have factory ones on now. What is the piping size factory on a 1994 LT1 base coupe?
Thanks.
To Cat converter ??
