How much power can...?
Old Mar 30, 2007 | 11:05 AM
caa5030's Avatar
caa5030
Default How much power can...?
How much power can a basically stock tpi intake support with a good bottom end, cam and heads? I know that this really chokes off the power. I am just wondering even if you get the bigger base and larger runners and maybe even port and match up the openings what kind of power one can expect the tpi to cut off at. Thanks
Old Mar 30, 2007 | 12:27 PM
vader86's Avatar
vader86
Under what caveats? NA? 350? stock heads? stock cam?
Old Mar 30, 2007 | 12:32 PM
Aardwolf's Avatar
Aardwolf
300 seems to be the cap.
Old Mar 30, 2007 | 01:40 PM
caa5030's Avatar
caa5030
383 everything Forged, 2.02/1.60 heads medium cam, NA, 10:1 compresion maybe 11:1 compresion
Old Mar 30, 2007 | 02:10 PM
vader86's Avatar
vader86
You could conceivably pull out 400+ with the right cam choice
Old Mar 30, 2007 | 02:16 PM
caa5030's Avatar
caa5030
Thanks a lot Vader. I have been reading some of your posts and some of your website and you are a very knowledgable person. I am thinking about building up a little and I just wanted to see what is realistic. Again thanks a lot for you insite.
Old Mar 30, 2007 | 02:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you want to add a little top end breathing with stock base & runners consider the siamese base mod.
Here's an example of what was obtained from a modded L98
To How much power can...?
