How much engine vaccum please help
Old Mar 30, 2007 | 02:40 PM
YoMilkMan's Avatar
YoMilkMan
Default How much engine vaccum please help
hi all
How much engine vac does a pretty stock tpi normally have. I just bought a FP and VAC gauge all in one.
thank You
88TPI
Old Mar 30, 2007 | 04:05 PM
toptechx6's Avatar
toptechx6
My stock 93 LT1 pulls close to 21" at idle, if you have a hotter cam it will be quite a bit lower.
Old Mar 30, 2007 | 06:38 PM
sami85L98's Avatar
sami85L98
U might be intersted in how to read vacum gauge:
http://www.secondchancegarage.com/public/186.cfm
mine is a highly modded holds very steady 17.5.
Old Mar 30, 2007 | 06:45 PM
Pete K's Avatar
Pete K
Altitude affects vacuum as well. I believe you lose 1 inch of vacuum for every 1000 feet that you climb.
Old Apr 3, 2007 | 01:11 PM
YoMilkMan's Avatar
YoMilkMan
great thanks everyone
Old Apr 3, 2007 | 05:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
21 in. Hg is pretty standard for healthy, stock automobile engines.
Old Apr 3, 2007 | 05:32 PM
Red Tornado's Avatar
Red Tornado
i'm actually a bit below sea level, the last time i put a gage on it read 16".
Old Apr 3, 2007 | 05:34 PM
Pete K's Avatar
Pete K
Brad,
16 is good for a 219 cam. I make about 13. My idle speed is stock though. Bumping up my idle to 800 rpm will likely add to the vacuum reading.
Old Apr 3, 2007 | 05:36 PM
Red Tornado
Pete, yes, I had my idle bumped by Alvin to 850.
I must make a correction. Where I live, we're actually about 450 feet above sea level. Pete, you're about 550.
http://www.topozone.com/
Old Apr 3, 2007 | 07:26 PM
kopbet89c4's Avatar
kopbet89c4
I have 20" of vacuum at a 600 rpm idle.
Old Apr 4, 2007 | 11:18 AM
tequilaboy's Avatar
tequilaboy
14-15" here. Comp 503 cam, 850 rpm, 32 degrees advance at 800 rpm.
To How much engine vaccum please help
