Convert cross brace
Old Oct 14, 2001 | 10:32 AM
RichS's Avatar
RichS
Default Convert cross brace
I just bought a vert x-brace for my GS. I looked in my Helms book and see there is a spacer for the parking brake cable, and a floor stud plate which I don't have. Any one who installed this on a coupe have any part#s and bolt sizes for these pieces?
Old Oct 14, 2001 | 09:48 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: Convert cross brace (RichS)
Rich
I would think you should be able to buy it from GM new.
Old Oct 14, 2001 | 09:51 PM
RichS's Avatar
RichS
Default Re: Convert cross brace (Corvette ED)
Yea I plan to but was looking for some #'s. Sometimes it's easier than having them look stuff up confused :rolleyes: Hey Give me your parts :D
Old Oct 15, 2001 | 09:02 PM
RichS's Avatar
RichS
So far the dealer is clueless :mad
Old Oct 17, 2001 | 08:24 AM
RichS's Avatar
RichS
Anyone have some info on this?
Old Oct 17, 2001 | 09:15 AM
Roar Hansen's Avatar
Roar Hansen
Hi!
Don't know to much about this, but looking at the parts fiche
http://www.carfiche.com/c4/index.pl?7:h:15
it looks like the reinforcement plate has part number 14092624. I couldn't find the spacer that you mentioned.
[Modified by Roar Hansen, 2:15 PM 10/17/2001]
Old Oct 17, 2001 | 12:35 PM
Hutch's Avatar
Hutch
Rich, try contacting Hank Engel at partsman427@starfishnet.com. He's a Chevy parts manager who has been very helpful before... and he loves the GS! ;)
Old Nov 1, 2001 | 03:34 PM
BryanC's Avatar
BryanC
I've done the X-brace on my 95 coupe. Looking at that fiche you need the part #'s 4, 5, 27, and 14. Quantity of four of the #14. Those are the spacers. The floor studs you can do yourself with bolts and large washers. You have to remove the seats and drill 4 holes in the floor. then drop some bolts with large washers on them thru the holes. Use some silicone here to prevent water leaks. All the bolts are 3/8-16. Get some grade 8's at the hardware store. The front bolt holes are already in the frame ready and tapped. The real trick is the rear bolt holes. If you are a welder make a plate to weld in there to give you some threads. The metal is thin here. I made the holes with a small drill bit to start them then used a punch to roll the metal in. Then I tapped the holes and JB Welded some studs in permanantly.
Old Nov 1, 2001 | 05:20 PM
BryanC's Avatar
BryanC
Default Re: Convert cross brace (BryanC)
Found the part #'s. The spacers are 10153644 at $7.99 each at Van Devere Olds. The reinforcement is 1409624 if you don't have it already. It just connects the 2 braces together. I always use Dal at Van Devere for GM parts. He does all the sales to the F-body group. The prices from him are typically half what they are at a local GM dealer. The number is 1-800-362-9494 ext 501.
To Convert cross brace
