re: LT1 Edit
Old Mar 31, 2007 | 12:26 AM
ebisko's Avatar
ebisko
Default re: LT1 Edit
Is Lt1 edit the only programmer for changing logged data? I have been thinking of running Datamaster for logging the data. Still unable to get a grasp on this tuning thing. Any and all info will be greatly appreciated. thanks in advance , Earl.
Old Mar 31, 2007 | 01:34 PM
MaxLean's Avatar
MaxLean
Tunercat is another alternative. It doesn't have any logging functions either so you will still need to use Datamaster. I have had both LT1 edit and Tunercat for a long time and while I started initially using LT1 edit, I'm now using Tunercat almost exclusively.
Scott
Old Mar 31, 2007 | 01:58 PM
ebisko's Avatar
ebisko
Default LT1 Edit ?
Thanks for the reply, Scott. I take it that you like to use Tunercat as opposed to LT1 edit, may I ask you why this is so. Thanks, Earl.
Old Mar 31, 2007 | 02:06 PM
STL94LT1's Avatar
STL94LT1
Tunercat is cheaper and can be used on multiple cars. LT1 edit is VIN specific.
Old Mar 31, 2007 | 02:27 PM
MaxLean's Avatar
MaxLean
My preference for Tunercat began when I started tuning for SD mode and needed to work the VE tables. Tunercat has better graphing features and made the job a bit easier. Also, Tunercat has many more secondary functions such as A/C load anticipate adjustments, injector flow display (allows you to fix the dash millage calculations when you change the size of the injectors), and various other functions. Also, the upload/download to the pcm is integrated into the main program. I'll always be a supporter of LT1 edit, but Tunercat is working better for me.
Scott
Old Mar 31, 2007 | 11:20 PM
rtracy's Avatar
rtracy
Ya Earl, Tunercat and Datamaster here. I started out on them both and am still useing them. It takes awhile but keep at it. Read, read, and more reading. I am still learning. Register with LT1edit mailing list and go threw the tunercat mailing list archives you'll learn alot.
To re: LT1 Edit
