What is this?
Old Mar 31, 2007 | 10:50 AM
ScaryFast's Avatar
ScaryFast
Default What is this?
EDIT: QUESTION ANSWERED. Read on only if you're bored.
Or if you're Aardwolf.
It's on the airbox, driver side. It looks like a hole where air can get sucked into the motor without going through the filter. Did something used to be plugged in here? Should I cap this hole?
Old Mar 31, 2007 | 11:04 AM
Aardwolf's Avatar
Aardwolf
I would cap it. Mine doesn't have that. What is that cover over the filter?
Old Mar 31, 2007 | 11:12 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
That's where the hose coming from an air pump (located in lower wheelwell) connects from. If the air pump is no longer there (you or some previous owner removed it), then I would cap that hole.
It's all part of the EVAP Canister Hoses.
Old Mar 31, 2007 | 12:30 PM
vader86's Avatar
vader86
Yeah you need to cap that off
Old Mar 31, 2007 | 12:46 PM
chaos on wheels's Avatar
chaos on wheels
Your local autoparts store should have this 3/4" 'bypass cap'. Fits perfectly!
-Jason.
Old Mar 31, 2007 | 01:41 PM
96GS#007's Avatar
96GS#007
A hose for the Air Injection Reaction (AIR) system goes there. Cap it off since it's behind the air filter and the engine will suck unfiltered debris thru there.
Old Mar 31, 2007 | 02:05 PM
ScaryFast's Avatar
ScaryFast
I removed the AIR system awhile ago...either I forgot to cap it or the cap fell off.
Either way, it's nicely capped and now ready to not send roadkill into my intake...
Thanks for the answers.
Old Mar 31, 2007 | 02:11 PM
ScaryFast's Avatar
ScaryFast
Not sure what you mean...the top of the filter is stock, except I cut off half of the rubber "thing" that is on top of the filter intake. You know, the whole cut lid mod. Got me like...35 hp
To What is this?
