Help with code 35 and 42 infl rest on -90
I have tried the K to ground and wait 3 seconds as mentioned on the forum but without luck.
This started out as i had to remove the airbag while working on my horn problem.
Fixed the horn problem but now i have this stupid light.
Anybody with a helms manual that can help me out?
Pelle
-90 vert
35 is inflator open circuit
42 is indicator lamp open circuit
Both the info display and airbag was disconnected when i was fixing my horn problem and then tripped these codes.
The pdf document on madvets homepage helped me with the procedure
3 seconds on,3 seconds off then 10 seconds on.(k terminal to ground)
Pelle
-90 vert
