intake tq specs
Old Apr 2, 2007 | 11:13 AM
excessive81's Avatar
excessive81
Default intake tq specs
doing the intake gaskets but need to know what to tq bolts down to.
thanks
shane
opps it l98
Old Apr 2, 2007 | 11:29 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
FSM is your best source, and, search the Tech section w/archives i know there were posts on TQ and Sequence, but sorry cannot remember which one.
Old Apr 2, 2007 | 12:00 PM
JAKE's Avatar
JAKE
I always use 35 ft./lbs with anti-seize on the threads.
I also dimple both China walls and the underside of the intake (both front and rear) with a nail set.
I then apply a 3/8" bead of sensor safe silicone on the China walls and, with my finger, apply a very thin layer around all the ports, both intake and coolant.
I re-torque the bolts several times until they hold the torque setting. As the gaskets take a set, the torque on the bolts loosen, so re-torquing is needed.
Hope this helps.
Jake
Old Apr 2, 2007 | 01:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 FSM recommends to:
1) snug the 4 center bolts and the two RR bolts
2) torque all the bolts to 35 lb-ft in the sequence:
2 LF, 2LM, 2LR, 2RF, 2RM, 2RR
Indeed, after all are torqued to spec I retorque and walk away for >24hrs to allow the RTV to fully cure and adhere to all surfaces.
Then I return, retorque the base bols and begin install the other intake components.
Old Apr 2, 2007 | 08:59 PM
excessive81
thanks guys...sure makes me appreciate the ls2 intake!!! kinda sucks i did all this work to pull intake to find oil allover the brass tube assembly coming off the back of the block. whoever worked on it last time didn't put enough thread dope to get it tight when it was in the right position. i pretty much sis all this for nothing
Old Apr 3, 2007 | 12:36 AM
Sam Lam's Avatar
Sam Lam
I know you did not ask, but torque the runner bolts to 25 ft lbs torque and use anti-sieze on the threads of the bolts.
Old Apr 3, 2007 | 02:52 PM
JAKE's Avatar
JAKE
Right. In fact - for future reference - use anti-seize on the threads of any bolt that screws into aluminum; including the spark plugs.
Jake
Old Apr 3, 2007 | 06:13 PM
excessive81
yeah i did guy but good for future refrence...thanks. nayone know what that brass piece is coming off the back of the bloock with the 2 sensors. weird spot surprised guys are not breacking them off actualy!
Old Apr 3, 2007 | 09:15 PM
JAKE's Avatar
JAKE
One is the combination oil pressure sender/fuel pump switch. Should be a bulb shaped gizmo, usually gold in color, with a single, male, spade connector. It's a sender for the oil pressure dash gauge but also will energize the fuel pump if the relay dies.
The other one is shorter, has a hex feature for tightening it and it's for - my mind just went blank of what it's for, let me chew on it a while. It'll come to me.
I'm sure someone else will chime in on that one bwfore my brain kicks back in gear. The game of "One UpsManShip" never ends. LOL
Jake
P.S.: I just awakened from a sound sleep and had the terrible feeling that the above info isn't correct. I was going from memory - and it hasn't been working too well for me lately.
Could be that the bulb shaped "gizmo" is the oil pressure sender for the dash oil pressure gauge and that's its only function. Then the other hex headed unit is what energizes the fuel pump.
Somebody please straighten me out on this so I can go back to sleep.
Jake
Old Apr 3, 2007 | 09:45 PM
excessive81
To intake tq specs
