Quad front brake calipers
Old Apr 4, 2007 | 01:56 AM
Hideki's Avatar
Hideki
Default Quad front brake calipers
A while back I saw a guy on eBay selling brackets that let you install TWO brake calipers on each of the front rotors. I should've bought them when I had the chance It looked amazing! Does anyone have any information on this setup?
Old Apr 4, 2007 | 02:34 AM
STL94LT1's Avatar
STL94LT1
Contact forum member Tom "tjwong" Wong. I'm pretty sure he has that setup on his 96.
Old Apr 4, 2007 | 03:32 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
He does. They bite hard on the first high speed stop, after that they heat up and fade.
AO engineering used to sell a kit. Porsche tried the same thing years ago and found it was better to use a single larger caliper.
Old Apr 4, 2007 | 06:51 AM
Tom Piper's Avatar
Tom Piper
The problem with that design is there is too much time the rotor spends covered by the caliper and pads -- not enough time to cool.
Big or multiple calipers are good for clamping force, but the also prevent cooling as long as the rotor is covered.
So, good first bite, but increased fade.
Tom Piper
Old Apr 4, 2007 | 01:48 PM
Mojave's Avatar
Mojave
I can lock up my wheels with a single caliper with agressive pads. Which tells me I don't need any more calipers.
Old Apr 4, 2007 | 04:38 PM
Jeffvette's Avatar
Jeffvette
And how many times can you do that?
Old Apr 4, 2007 | 05:31 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Since stock brakes can lock a wheel two or three times, that isn't really the issue.
Fade is.....
and, since rotor mass and cooling determine pad fade, two calipers shouldn't change those two characteristics.
I'd think doubling up on calipers would only add to (unsprung) weight.
You're probably lucky that you missed out on the Ebay sale.
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 4, 2007 | 11:58 PM
Mojave's Avatar
Mojave
With the XP10 pads I run all the time (even on the street) with C5 front brakes, until I run out of tires.
Old Apr 5, 2007 | 12:12 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
That's pretty much it. It will take a little longer to heat up two sets of pads generating half the friction, but the rotor will lose some cooling ability with another caliper on there, so it's a wash.
You could go longer between pad changes though!
Ultimately your tires are taking energy from the car's speed and dumping it into your rotors. Your rotors have to dissipate that as heat. The pads are just the intermediary. As long as the pad compound can withstand the rotor temperatures, they aren't the weak link.
Most people don't understand much about brakes and just throw parts/money at their cars until they stumble on the solution.
Old Apr 5, 2007 | 12:46 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Who would want all that unsprung weight?
To Quad front brake calipers
