" adjustable fuel regulator "
i was just wandering please guys some info if i may!
when adjusting fuel preasure with a adjustable fuel regulator do you need to remove the vacuum pipe on regulator to adjust for the rite preasure and then fit hose back on please?
can you give me a correct procedure run down in steps please!
what is a good fuel preasure to run with a " supe ram " intake also please?
thanks guys
bye the way " HAPPY EASTER " guys for sunday!!!!!!
cheers
glen
Australia
thanks for your reply and help mate!
but is it necessary to remove the vac line hose to adjust it properly/to get the rite preasure though please?
is it a good idea to change the old fuel preasure regulator diaphram for a new one in to help with increase the fuel preasure as well?
thanks
glen
I set at 44 psi w/vacum unhooked with 24 injectors, and i hooked my aldl connector with my laptop, took a test drive, at idle and at stop lights BLM readings were 132-138 and while drive at low speed blm = 128 (perfect below 128 is richer ) and at 4400 rpm=135 mph speed, blm's were 124 perfect i want it to be just little richer side.
So if u have laptop, S/w(winlaldl in my case) take a test drive an dobserve blm's at idle, slow speed and than high speed (u dont have to go 135 mph speed though).
1-measure stock fuel pressure with the stock FPR installed
2-install the AFPR and set pressure to the stock value
3-measure HP
4-bump pressure by 4psi
5-repeat 3 & 4 till HP begins to drop off and back off 2psi
If you don't have a chassis dyno or drag strip you can get a crude measure of HP by measuring acceleration between two fixed points about 1/4 mile apart. In the latter case I would measure both MPH & time.
