From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by JAKE
Not sure what your point is, but I borrowed my friend's - Alfred Johnson's MAF who lives in Red Oak, TX off his 85 - mounted and plugged it into my 86 and it worked like a charm.
I've heard that but does it mean they're backwards compatible too? The 85 and 86+ MAFs are different in the signals they produce for the ECM.
Originally Posted by GlennS87
Did you recently add an oil impregnated filter (i.e. K&N)? Sometimes people over oil them a little and the wire of the MAF get coated with the oil which causes erratic MAF operation.
Naw, K&N insists that it's impossible for their filter oil to get on the MAF. Then they go onto say oil is getting on them from the crankcase or combustion chamber instead.
Yep, I've read the same thing, but I've posted several times about my experience with the K&N. I wasn't surprised at K&N's response, afterall, what else could they say unless they were willing to kill their market share. LOL
I installed it out of the box and a few weeks later happened to hook up Diacom and noticed 108 BLMs. After checking everything I could to bring them back to the range of 128, I pulled the MAF.
I gave it a few shots of carb cleaner, buttoned everything back up and the BLMs returned to normal.
So I removed all the red oil from the K&N filter and haven't had a problem since. BLMs remain in the 126/130 range for several years now. If "crankcase" or "combustion chamber" oiling was the source it would have re-coated the MAF wires by now.
Anyway, that's my experience, in spite of K&N's denial.
My throttle blades get dirty on the BACK side, but are squeaky clean on the front side, so I find it hard to believe that something is coming back out of the engine and getting on the MAF wire.
