" bfg kd 315 mm tires "
Old Apr 5, 2007 | 10:43 PM
sxyvet's Avatar
sxyvet
Default " bfg kd 315 mm tires "
hi there guys,
i have 315 x35x17" Summitomo tires on my vette !
i heard that the summitomo tires are a thinner/skinier tread pattern than other brands!
and they wont look as wide as other brand tires in the same width/series/diameter!
appraently the summitomos although quite cheap to buy have a rounder wall edge!
any way i am looking at to buy a set of " bfgoodrich KD tires ,315x35x17 " @ $ 260.00 each!
they ahve a nice agreesive tread pattern that goes rite to the edge and has a lovely square edge to them to give a wider look to them!
has any one tried these tires at all please?
how have they handled?
have they worn well?
do you have any close up rear end pictures of them fitted to the car at all please?
cheers and thanks
glen
bye the way " HAPPY EASTER MY FRIENDS FOR SUNDAY "
Old Apr 6, 2007 | 06:36 PM
sxyvet's Avatar
sxyvet
" any one out there ??? "
any ideas or info please!
cheers
glen
Old Apr 6, 2007 | 07:08 PM
Aardwolf's Avatar
Aardwolf
cheers
glen
To check the size of different brands of tires, goto tirerack.com if you select a tire then check the specs tab. This will show you how wide each brand of tire is. It's also great to check the tire weight, and overall dia. so it's not to big.
Old Apr 7, 2007 | 01:39 AM
KCHOTBOAT's Avatar
KCHOTBOAT
I had Yokohama AVS Sports on my car and I like the Summitomo better. The ride is better and they stick better for me at least in autox.
Old Apr 7, 2007 | 05:53 PM
sxyvet's Avatar
sxyvet
hi there guys,
thank you for your replys r.e the bfg tires!
cheers
glen
happy easter!!!!
Old Apr 7, 2007 | 07:17 PM
c4cruiser's Avatar
c4cruiser
The BF Goodrich KD is an excellent dry weather tire. It has excellent grip and works well for high performance driving and is usable for HPDE and track days. Hard driving in the rain is another matter altogether.
Don't expect long life from the BFG KD tread; I think that the tread depth is much less than other tires in the same size. The KD comes in a left side and a right side tire so if you do go with them, make sure the tire store gets that part right!!
There is a tradeoff between grip and mileage in the ultra high performance types of tires. As far as the overall width of the tread, that can vary from brand to brand. With a tire that has a section width approaching 12-13 inches anyway, a difference of an inch should not be noticable.
Unfortunately, you have probably found that there are not too many supplies making a 315/35-17 tire anymore (I think that if you do a search on the Tire Rack website, you will only find 4 or 5 brands in that particular size.
A friend has a 90 ZR-1 with Sumitomo's on them and they really did not last that long. He doesn't drive it hard but after 40K miles, the tires were down to about 25% tread depth.
IMHO, you would probably be better off with the Goodyear F1 GS-D3 for overall performance and better trtead life. They are quieter on the road too. Tire Rack shows them for only $10 more than the KD.
Old Apr 8, 2007 | 07:12 PM
sxyvet's Avatar
sxyvet
Default thanks for the cool info!!!
hi c4cruiser,
how are ya!
cool man , thank you for the cool tips and your help mate!
the main reason i like the bfg kd tire is as it has a nice square wide stance that i am after!!!
unless you know of any other square side wall wide tread looking tire may be mate please?
do you think the good year f1 gs-d3 has a nice square stance to it?
thanks alot for your advice and help mate!!
cheers
glen
Australia
Old Apr 8, 2007 | 08:23 PM
JackDidley's Avatar
JackDidley
I wore out Summitomos in 4K miles. Best I got was 8k.
Old Apr 8, 2007 | 09:00 PM
imputor's Avatar
imputor
I've heard a lot of good things about the BFG KDW from my camaro buddies, and they're a wet/dry summer tire on top of being cheaper than the KD's. Yes they come in a 315/35/17.
Old Apr 8, 2007 | 10:15 PM
sxyvet's Avatar
sxyvet
hi imputor,
how are ya mate!
can you please tell me the differnce between the bfg kd and the bfg kdw please mate?
cheers
thanks
glen
To " bfg kd 315 mm tires "
