fuel kill switch?
Old Oct 15, 2001 | 03:55 PM
8URVIPER's Avatar
8URVIPER
Default fuel kill switch?
on the C4's where are that at?
steven
Old Oct 15, 2001 | 04:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: fuel kill switch? (8URVIPER)
The computer is the only fuel kill "switch" that I am aware of.
Old Oct 15, 2001 | 04:58 PM
GlockLT4's Avatar
GlockLT4
Default Re: fuel kill switch? (Vette92)
what about splicing in a switch to the fuel pump?
Old Oct 15, 2001 | 05:57 PM
mash557's Avatar
mash557
What year vette? Their is a switch on the L98's that is coupled to oil pressure. It is located in a very inaccessible spot on the drivers side of the distributor. This allows the fuel pump to run after the initial fuel pump run that the computer allows when the key is turned. No oil pressure, no fuel pump run. Now that being said it could be a bad pressure switch or the wires fell off, but after trying to take the wires off, I don't think that would be the case. You could take the two wire harness off and jumper it and if the fuel pump runs and the car starts and runs okay, then the oil pressure switch would be at the top of my list of things, especially if you have good oil pressure when it cranks. Good Luck
:seeya
Old Oct 15, 2001 | 11:39 PM
8URVIPER's Avatar
8URVIPER
Default Re: fuel kill switch? (mash557)
yes its a 85 L98, where is it at? driver side you said? is it a button or what ? thanks
steve
To fuel kill switch?
