92 Optispark
Old Apr 13, 2007 | 09:00 PM
sothpaw2's Avatar
sothpaw2
Originally Posted by Rsmi51
I'm going to change my optispark before having any problems. Has anyone used either the MSD or the Dynaspark for a 92? I have also thought about using the GM and doing the venting my self. Any thoughts?
Leave it alone, do not replace unless it is broken and the car won't run. I spent good money "while I was already in there" to do a new opti, and the new opti was bad out of the box. This was 4 years ago, but still...the old opti never did anything wrong and I would have saved money, time, and trouble leaving it alone.
Old Apr 13, 2007 | 09:07 PM
Strick's Avatar
Strick
I have a 92 and started out trying to fix an oil leak. Here is a long tech tip I did about the whole opti/wires/plugs/coolant pump/timing cover seal replacement/etc. https://www.corvetteforum.com/techti...=231&TopicID=2
Once you're done it will last and you will have peace of mind.
Old Apr 13, 2007 | 09:13 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I went with the Dynaspark due to the track record.
Was well worth the money and is working great for me!
