I just replaced the injectors in my 85 and I thought I had all of the vacuum lines well labeled until I began to put it back together!! On the right side the vacuum line that plugs into the T that goes into the back plug on the plenum came disconnected and broke. I had an extra from the last time I had it apart but don't know how to route it. It came apart at the front end on the left side so I'm really lost!! Does anyone have a diagram that will help me figure out how to hook up all of the vacuum lines again. I am also questioning the routing to make them all fit around the runners and fuel rail is greatly needed. Any help will be greatly appreciated. I'm thinking a cold one is the only way out tonight but I want to get it back together tomorrow night if I can. Thanks.
I have my plenum and runners off at the moment, so I'm jogging through my memory of what you're asking... the only T fitting I can remember near the rear was the one that came off the plenum into the T fitting... from there one part of the T goes to the fuel pressure regulator and the other line goes to the air diverter valve.
The only other T I had was the one that plugs into the TB.
