" camber brace install "
Old Apr 8, 2007 | 07:32 PM
sxyvet's Avatar
sxyvet
Default " camber brace install "
hi there guys,
i just installed a straight bar camber brace on my 1991 vette!
i have a straight bar brace as i dont have air cond!
any way can any one please tell me if they had to move there power steering resovoir further out of the way please?
my resovoir is located on the left hand side of the car in front near the alternator!
is this where all the power steering resovoirs are placed as my vette is right hand drive thats all and im not familliar if thats where it should be or not?
any how after installing the brace , i have noticed that when i tried to fit back my resovoir that it wont fit there any more due the camber brace cross brace bar now!!
is this normal please?
did you have to move your resovoir across more?
or may be when i fitted it i should have removed the power steering resovoir before i installed the brace?
im thinking that i might have to look around at the motor wreckers for a smaller /more up rite type of power steeering resovoir so it will fit ?
any ideas/help please guys!
cheers
happy easter
glen
Australia
Old Apr 8, 2007 | 08:03 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
OOOPS, I missed the part about the right hand steer. Sorry, I can't help a bit except that my a/c dryer is on that side and I did have to raise it up just a tiny bit. Don't know about yours.
Old Apr 8, 2007 | 09:18 PM
Steel Blue 91's Avatar
Steel Blue 91
Here is part of the install instructions for the Camber Brace for my 91. Since the PS reservior is on the left (like stock LH drive) it should be the same. There is a small recessed area in the backside of the bar to accomidate the top front of the reservior.
"Remove the upper reservoir bolt and rotate it rearward until it contacts the frame support. Make sure the lower bolt is tight and leave the top bolt out. The Brace will hold the reservoir in place, once installed".
I can email you the instruction sheet if you like.
Old Apr 8, 2007 | 10:02 PM
sxyvet's Avatar
sxyvet
hi steel blue 91,
thank you for your helpful tips mate!
if you could please email me the istruction sheet would be really great thank you mate!!
you can send to sxy_corvette@hotmail.com
cheers for that
glen
Australia
Old Apr 8, 2007 | 11:10 PM
Steel Blue 91
On it's way.
Old Apr 8, 2007 | 11:15 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yours is probably much different, but on my 85, it was in the way of the reservoir too, only by maybe 1/2" or so.
The reservoir bracket attaches to the radiator shroud.
I bend the front arm of the res bracket up, and reattached it, this tilted the reservoir forward away from the camberbrace.
Old Apr 9, 2007 | 06:44 AM
sxyvet's Avatar
sxyvet
Default thanks guys!!!
hi there bill (steelblue91) thanks for sending me by email the instruction sheet,cheers!
hi centralcoaster,
how are ya!
thanks for your help also mate!
i think what i have done wrong was before i started installing the camber brace i removed the power steering resovoir first, now i cant fit it back properly!
i should of left it were it was first then installed the brace!
but i try and work around it and figure it out!
cheers
thanks guys very much!
glen
sxyvet
Australia
Old Apr 10, 2007 | 07:11 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Youll be right Glen, just make a new bracket for the power steering resevior. If your car was converted to right hand drive properly, none of that should have been changed at all. You can probably put the resevior anywhere along there where it wont be in the way.
Old Apr 10, 2007 | 05:38 PM
sxyvet's Avatar
sxyvet
hi casey,
thanks also for your advice mate!
cheers
glen
Old Apr 10, 2007 | 05:58 PM
JAKE's Avatar
JAKE
Yep, had the same problem on my 86. I just finessed it around until it cleared the brace.
For my car, it wasn't difficult to do. All I did was look to see in which direction it had to be moved and by how much.
Jake
Old May 9, 2007 | 08:56 AM
LD85's Avatar
LD85
Anyone have pics of an 84-87 camber brace install they could post please?
Old May 9, 2007 | 09:37 AM
Midnight 85
Here's the camber brace on my '85. Not much to see, if there's any questions I can answer for you just pm me.
Old May 9, 2007 | 09:43 AM
LD85's Avatar
LD85
Thanks, looks like a straight bar, I guess I dont need one that is bent or curved.
Old May 9, 2007 | 11:07 AM
ScaryFast's Avatar
ScaryFast
You don't need one at all, really...
Old May 9, 2007 | 11:25 AM
LD85's Avatar
LD85
Not for a stock setup your correct, but I just pulled my mono spring off and went to QA1 coilovers and I would like to stiffen up the shock tower area.
I plan on putting a spacer between the back of my tower and the A-arm mount then adding the Camber Brace, should be super duper stiff then.
Old May 9, 2007 | 12:00 PM
Aardwolf's Avatar
Aardwolf
Will it help anything? I haven't seen any data that it does. Let us know!
Old May 9, 2007 | 01:13 PM
BerniesVette's Avatar
BerniesVette
I made one for my 79 and it made a world of difference. With the brace across the front on a C4 it would seem that one isn't needed.
Another good way to stiffen the front is install solid engine mounts. this really helped my C3 too. Just a thought.
Bernie
To " camber brace install "
Old May 9, 2007 | 03:53 PM
ScaryFast's Avatar
ScaryFast
Why in the world would you want it super duper stiff? The C4 has a significant amount of understeer inherent in the suspension set up. Stiffening up the front will make it worse.
Old May 9, 2007 | 03:57 PM
LD85's Avatar
LD85
If you read my posts above, they state that I have changed to Coilover suspension, I do nolonger have a MONO SPRING.
Without the spring, the shock tower suports each corner of the car's weight, so I dont want deflection on the shock tower.
Old May 9, 2007 | 04:32 PM
ScaryFast's Avatar
ScaryFast
I'm just trying to save you some money. I also have coil overs...no camber brace. I road race the car exclusively, and handling is superb without the brace. Good enough to take first at Mid-Ohio last month, anyway.
