What is this part?
Old Apr 9, 2007 | 10:25 AM
daniel0213's Avatar
daniel0213
Default What is this part?
I'm trying to put this car back together (90 vert) from a box of parts. I have 4 Little black, plastic (hard) blocks about 2 x1x1 with 2 equally spaced holes going through it! The space between the holes is the same as the injectors, but i can't see them having anything to do with that! I can't figureout how to post a picture, so maybe my description is enough! any thoughts?
Old Apr 9, 2007 | 10:27 AM
Wheelman's Avatar
Wheelman
I can't think of anything off the top of my head...Maybe its something speed density related since you have a 90. If you email me the pic I will host it for you. Email
Old Apr 9, 2007 | 10:44 AM
pr1mu5's Avatar
pr1mu5
Are they like a bushing? I had just had my rear wheels off this weekend, and noticed some hard rubbery bushings that match that description inside the wheel well, I guess to stop suspension from getting smashed against the body when hitting potholes or something...
Old Apr 9, 2007 | 07:30 PM
KeyWestJack's Avatar
KeyWestJack
They sound like the spacers from the x brace to the frame. When you remove the x brace the rear connections have spacers about that same size. They are black in color and are made of pretty dense plastic.
Old Apr 9, 2007 | 08:08 PM
87 rag's Avatar
87 rag
This is exactly what I was thinking.
But...you say you have 4 of them. You should only have two.
Old Apr 9, 2007 | 08:43 PM
RRT vette's Avatar
RRT vette
It's just a guessing game w/o pics.
http://forums.corvetteforum.com/forumdisplay.php?f=31
Old Apr 9, 2007 | 09:37 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Sorry, but unless there is two different designs for the x-brace he does need 4 of them, two per side at the rear mounts. The one I bought from a forum member and put on my 85 needed 4 of them. However, the dimensions for them are approx. 2"x2"x1", not 1"x1"x2'. So as RRT vette said, we need pics.
Old Apr 10, 2007 | 08:15 AM
87 rag's Avatar
87 rag
You are right Midnight. 2 per side.
I stand corrected.
Old Apr 10, 2007 | 03:06 PM
daniel0213's Avatar
daniel0213
i will try to post pics asap! that leads me to my next question! I don't have the x brace! i have the holes so i can only assume that i need one! Where can i get one??? are they expensive?
Old Apr 10, 2007 | 03:27 PM
creoleman's Avatar
creoleman
Daniel, I don't want to open up a can of worms here, (the "need" for an X-Brace has been a contentious issue in the past on CF) but my car has, in my opinion,substantial chassis flex WITH the X-Brace. Just my two cents worth...
Old Apr 10, 2007 | 04:28 PM
daniel0213's Avatar
daniel0213
well, if the car came with it, i want to put it on! Are there aftermarket versions, or do i need to find one in a junkyard?
Old Apr 10, 2007 | 05:32 PM
thebeerman's Avatar
thebeerman
I'm with the rest if the group. I just dropped my exhause system to but in a B&M short throw, and those sound like the blocks that space the rear of the cross members. Last year I pulled the intake manifold and went over the entire top assembly and don't remember any parts from that section of thhe engine that sound like them. If people who take things apart would only learn to use labels!!
Old Apr 11, 2007 | 06:27 PM
KeyWestJack
this is an after market http://www.parts123.com/parts123/yb....Z5Z5Z50000050F (looks like a different bolt pattern though) , but some of the used parts sites should be able to fix you up with an original.
Old Apr 12, 2007 | 03:07 PM
daniel0213's Avatar
daniel0213
Which sites are those??
To What is this part?
